What Polks are these?
Mystery
Mystery Posts: 2,546
edited May 2014 in Vintage Speakers
And their worth and sound?
Post edited by Mystery on
    pitdogg2 Posts: 27,187
    edited May 2014
    towers are RT2000P other looks like Ls series
  • ken brydson
    ken brydson Posts: 9,011
    edited May 2014
    There weren't any LS bookies AFAIK...
  • Mystery
    edited May 2014
    Thanks.
    So I guess $500 is too much for the two towers, two surrounds and a center along with a BPC Yamaha receiver.
  • ken brydson
    edited May 2014
    Actually the bookies may be LSfx's. Just looked at mine and from that angle you cant's tell that the cabs are tapered.
  • Mystery
    edited May 2014
    I don't think they are RT2000P.
    RT2000P look like these, notice the different tweeter/mid housing shape as well as two piece grill instead of one piece in my post above:
    Edit: Found it, they are RT20P:
    http://www.polkaudio.com/products/rt20p
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2014
    You beat me to it. Those are indeed RT20P's. The smaller ones are LSFX's. If the center is the CS350, then I'd say that system is probably worth it, especially with the receiver. I would be careful with the 8" drivers, though. I think they used the same drivers in my old RT16's and RT7's and had more than one of them go out on me. That's why I decided to get rid of them. As far as sound goes, the RT16's and CS350 were incredible. I would imagine that the RT20's would be pretty close in performance.
    Mystery wrote: »
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • rooftop59
    rooftop59 Posts: 8,120
    edited May 2014
    Those might be worth the coin if you are going to keep them, but not for the speaker merry go round...they may be difficult to unload for what you paid.
    Game Room 5.1.4:
    Bedroom 2.1
  • Nightfall
    Nightfall Posts: 10,083
    edited May 2014
    Pass. I still say you should sell half a bajillion of your bajillion speakers and use the money to get a pair of SDA 2.3 or 1.2's.
    afterburnt wrote: »
    Village Idiot of Club Polk
