what is the best way to enlarge a record hole that won't fit on tt spindle?
pglbook
I recently have bought a few used records that won't fit comfortably on my turntable spindle.
What is the best way to enlarge the record hole so it will fit on my tt?
Has anyone else had this problem?
I have a Thorens TD 160 turntable and I have read online that vintage Thorens turntables used a spindle that was a little thicker than the spindels of other turntables. Luckily it has not happened too often but there are a 3 or 4 records I have bought in the past 6 months that are too tight to fit comfortably on the spindle.
Thanks.
Thanks.
Post edited by pglbook on
I would think the only way to do it would be with a drill. Just be real, real careful because if that hole is too large the record won't be stable. Maybe test with a piece of wood first.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Round rasp. Use a twisting motion to gently enlarge the hole. If you can, hold it upside down so any shavings fall clear of the record.
A " rat tail file" graduated in size over its length will work fine just be gentle.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Thanks for the feedback! I look forward to being able play the few records that wouldn't fit over the tt spindle.
It's funny that most records I bought (used or new) were fine but a few were too tight. You would think there would be a uniform size hole for vinyl records but obviously that is not the case.
Thanks again. I appreciate it. -
Dynamite....My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
scrape off or file the spindle until it's thinner... :wink
It'll fit all records after that.
Interesting thread.cant say ive ever seen that happen. Hope that fixes the issueRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Measure the spindle a and buy a reamer.
Buy the cd version...no holes.HT SYSTEM-
lsi 9's -
7mm drill bitMain System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis -
This thread reminds me of the "air-hole" thread.--Gary--
a little dab of K -Y has helped spindles fit the hole for years."she had the body of Venus, with arms."
An old # 2 pencil did the trick! Sometimes the simplest solutions are the best.
Thanks again for all the feedback. -
Audioquest makes a spindle drill (by hand) to use to make holes larger.[
get a stepped drill bit, they are made to enlarge existing holes.
http://www.irwin.com/tools/browse/drill-bits/unibit-step-drills
something similar to these, the second one looks about right.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
seabeerob213 wrote: »get a stepped drill bit, they are made to enlarge existing holes.
third if you need metric, which i believe you did.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
