Martin Logan Monolith MkIII opinions?
nooshinjohn
nooshinjohn Posts: 26,000
edited May 2014 in Vintage Speakers
Found a pair of these locally in mediocre shape that need to be (except for the panels) completely rebuilt from the crossovers up.
I am unable to get ears on them because they are completely dis-assembled, and the woofers are shot, needing to have the surrounds redone at a minimum. Once these are restored, what would I expect to hear from them sound-wise, and would they be worth the time to put back together even?
Post edited by nooshinjohn on
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2014
    RUMOR REPORT: Not confirmed!
    I heard that Martin-Logan dumped all their spare parts for older speakers, and the customer service took a tumble. Anyone else hear similar?
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    You would be better off with a QuAD Stack system!!
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
    edited May 2014
    DSkip wrote: »
    I'd suspect if they've got some age on them, you'd be better off passing. If the rest of the speaker is torn to hell, I wouldn't expect much more from the panels, and that's the most important/expensive part of the speaker.
    Panels are new-in-the-box already from Martin Logan.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2014
    John those speakers are proper money pits and the price of a woofer should it fail will be in the thousands and all the parts are crazy expensive for not that much in return. All the new lines have smaller panels but the new panels put out twice as much sound per square inch due to the new design in the perforation of the mylar. My opinion is that if you want some logans then seek out a pair of used summit for under 5k.
    The bonus thing about the speakers your looking at is if those panels are brand new because your talking a couple of grand for those.
  • deafbykhorns
    edited May 2014
    A friend of mine had those same speakers and finally sold them after a panel failure
    He's running some old quads which are much more robust, heck they are 40yrs old with no failures except a HV cap
