These aren't Monitor 4's are they?
Nightfall
Nightfall Posts: 10,083
edited May 2014 in Vintage Speakers
http://denver.craigslist.org/ele/4430829586.html
Is the picture just making them look different or are these actually Monitor 5's?
afterburnt wrote: »
Village Idiot of Club Polk
Post edited by Nightfall on
  • Nightfall
    edited May 2014
    It kind of looks like the grills go all the way to the bottom of the speaker, but it's really hard to tell. Might just be the angle of the pic, I'm not sure. My early Peerless Monitor 5's the grills stop an inch from the bottom and the Polk logo is attached to the cabinet instead of the grill. I'd guess these are SL1000 or later but, again, the picture isn't very good quality.
    afterburnt wrote: »
  • Nightfall
    edited May 2014
    nbrowser wrote: »
    hrm my Peerless Monitor 5s have the grill going all the way to the bottom, badges lower right hand corner on the grills as well, not on the cabinets. Just like the ones pictured. One MW6500 is dated for September '79 if that helps.
    Interesting and informative, you never know with the older Polks! I swear I learn something new about them everyday.
    afterburnt wrote: »
  • Mystery
    Mystery Posts: 2,546
    edited May 2014
    May be but they look little short to be 5's .
    Could be 4.5's.
  • Zentish
    Zentish Posts: 127
    edited May 2014
    Those really look like 5's to me, but not 5B's as my 5B's have a beveled angle on the front. Next to that CD changer they look taller than 5jr's but shorter than 7's. Do the M5 series 2 have the bevel? I can't remember...
    Anyways, if none of the drivers are blown they're well-worth the $40 asking price.
    I've never seen a 4.5 or 4.6 so don't know about them...
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • Mystery
    edited May 2014
    I stand corrected.
    They are 5's with peerless tweeters but one mid woofer is replaced.
    I'm not in a mood to get more speakers though so get them Nightfall if you want to add another peerless pair.
  • Nightfall
    edited May 2014
    Did you contact the seller? What was the MW replaced with, Polks replacement chinese woofer or some random 6.5" that happened to fit?
    afterburnt wrote: »
  • Mystery
    edited May 2014
    Yes I did. The woofer is not Polk.
    Here is a pic he sent.
