Jriver skipping
11tsteve
Skipping has been an issue for a while in Jriver. Usually very short interruptions, and intermittent in nature. I can listen for hours with no incident, and then get 5 skips in 20 minutes.
Usage is such that I am most often actively using the computer while listening, but even if I am away from the desk, listening while elsewhere in the house, it will still skip.
Last week, I changed out the cpu and RAM (AMD 8350 8 core @ 4.8Ghz, 8 GB Gskill Ripjaws). And a fresh install of Win7 64 bit on ssd. Though I didn't have any long listening sessions, I had no skips UNTIL I updated the Flash plug-in for Chrome... and now it is a daily occurrence.
Digital chain is My Book Live cloud drive to Netgear router. Computer has HT Omega card (drivers installed) with Huffman D.I. to Peachtree Dac-It.
I am using ASIO4ALL generic with Windows audio disabled. I have tried WASAPI and Direct Hardware, they all skip. I feel confident I can rule out cpu/RAM overload.....
I have tried all forms of buffering, port forwarding for the external drive, disabling drivers, etc and am just going in circles.
I hope I have provided enough info... if not, let me know. But please lend me a new direction....
Steve
Steve
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Keces DA-131 mk.II
Post edited by 11tsteve on
Definitely sounds like you have the hardware end well covered.
Have you noticed that the bit depth or sample rate has anything to do with the skipping?
How 'bout trying to undo the Flash update?Wristwatch--->Crisco -
I thought I read somewhere where Chrome plugins can cause conflict with JRiver and other programs. Maybe google for that and see if you catch a fix.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Yes, I did immediately uninstall the Flash plugin.SCompRacer wrote: »I thought I read somewhere where Chrome plugins can cause conflict with JRiver and other programs. Maybe google for that and see if you catch a fix.
it happens with Firefox as well, and even without a browser open.Polk Lsi9
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
upon further investigation, it would appear I can trigger the skipping by flipping the light switch in both my office (were the gear is) and in the dining room. I have not gone father investigating every switch.
It will not skip on every flip, but if keep hitting the switch, it will eventually start skipping and then continue... each skip coinciding with a flip in which the lights turn on.
So, it would seem I have a bigger issue. I had a fully grounded 20A line installed just for the audio gear, and the computer is on another line in the office, so my mind tells me the problem goes back to our breaker box. The incoming service to the house was replaced two years ago, the box & sub-panel are a nice Square D, and the two electricians who have seen the box said things look good. So I am not sure if just adding a power condition is the answer, or if I should be worried about a bigger potential problem.Polk Lsi9
Keces DA-131 mk.II
A ONLINE UPS for the PC would help, but it would be nice to know why exactly it's happening."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I like to use a simple tester to ensure things are connected properly at wall outlets. You can get them online or at Home Depot.
Does your office light switch also have a dimmer on it or is it just on/off?
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
All switches are just on/off.Polk Lsi9
Keces DA-131 mk.II
well, i have new found facts.
i have been chasing many tails, and believe I have come to a conclusion. I believe the issue is my Peachtree DAC*It.
I hooked a cd player directly to the pre, hit every switch and took every action I have found to cause skipping, and there was nothing. Not a single skip.
However, if I hook up the cd player to the DAC*It via my Huffman digital IC, it takes next to nothing to get things to skip. and of three switches will trigger the skipping. So, either the Dac or the cable..... I am hunting down a TOSLINK cable to help rule out the cable.
I have purchased this unit....APC 1200 voltage regulator...http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=LE1200
and the Dac is currently plugged into that, but the APC doesn't appear to be helping. Which confuses me. Any thoughts anyone?Polk Lsi9
Keces DA-131 mk.II
nevermind... problem solved. my Huffman cable has a bad RCA connector. How that picked up electric switches and refrigerators turning on, I would love to know.Polk Lsi9
Keces DA-131 mk.II
ok... new info.
The Huffman cable was sent and repaired.
I then found the Coax port on my HT Omega card had a bad solder. That has been repaired.
And still, the music skips when this cable is used in conjunction with the sound card. It still can be triggered with the light switch.
But it does NOT happen, ever, when using TOSLINK.
And, if I hook a cd player directly to DAC using the cable, there is no issue. Never a skip, light switch or not.
So, for some reason, that specific jack on the sound card is picking up some sort of EMI? Maybe?
Any other thoughts as to a cause or possible fix?Polk Lsi9
Keces DA-131 mk.II
You've already investigated areas that I wouldn't have thought of (at least in a short period of time)! It's obvious there's some sort of EMI issue going on if the Toslink interface is working (I use Toslink instead of coax whenever possible), but I'm not sure you'll ever completely solve the issue if there is design (grounding) problem with the sound card itself.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
My Dac will drop the signal when the electric stove upstairs in the kitchen switches the burner on every time and every time the furnace shuts off. It is called ground bounce. It is a spike through the ground. The optical connection may solve the issue because there is no ground. Does your Dac use the ESS processor? My twisted pear audio Dac uses the ESS 9018 chip and they are very picky about ground noise.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
and the outlet for the audio gear, and the outlet for the computer, are on two separate feeds, both new, both 20A, and both grounded.Polk Lsi9
Keces DA-131 mk.II
Try useing one outlet for both the computer and the Dac.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
Understand that this has been a journey of months, so my optimism is tempered. But, it this solves the problem, you are my ****ing hero. Thanks bikerboy.
But do you think it is the DAC still, even though I couldn't replicate it with DAC only? Or is it something in the relationship between the DAC and the computer?Polk Lsi9
Keces DA-131 mk.II
and yes, the DAC-it uses the ESS Sabre 9023.Polk Lsi9
Keces DA-131 mk.II
ah. I think I understand.... the DAC was singular before, and the cd player on the same circuit, but since the computer was on a separate circuit, and not of common ground, this is what caused the bounce. So, ultimately, it is the DAC.Polk Lsi9
Keces DA-131 mk.II
I have looked at this issue for quite soom time and it has been very frustrating. The ESS dac chips are very sensitive to a high quality signal and they let you know when it isnt good. I get dropouts sometimes but I have finally figured out the source and can deal with it. Glad I could help, it seemed you had it solved with the bad cables.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
nope... still skipping. not as frequent, but still does.....Polk Lsi9
Keces DA-131 mk.II
ok, try something new. I've had lots of skipping problems.
Source- POWER MANAGEMENT. Green motherboards and
newer OS tend to do some funky stuff. Go into your operating system
and turn off the green stuff. Don't let it throttle down your processor
speed."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »ok, try something new. I've had lots of skipping problems.
speed.Polk Lsi9
Keces DA-131 mk.II
ok, so just as a double check, leave your task manager up and open into performance monitoring.
I would assume that things are going haywire when it skips.
Also, have you looked into a small ups for the pc?"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
there is nothing that happens, visually, in any of the PM's live graphs. I have checked that, and Event Logs. Did you have something specific in mind in the performance monitor, or something that you have seen in your case?
Currently, the computer is plugged into this..... http://www.posglobal.com/LE1200.html
Part of me is starting to wonder if it is the DAC, but maybe not what we discussed earlier with the ESS chip, but possibly the fact that this Peachtree uses a power dongle instead of a three prong power cord.Polk Lsi9
Keces DA-131 mk.II
Keces DA-131 mk.II
just generic troubleshooting. That is all very strange.
other than a power line monitor, or a ups,
you're pretty much done."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Do you have an IR remote in the room, connected to the PC?
Do you use compact florescent lights in the room?
I've seen CFL lights create interference with my IR remote and remote repeater pretty randomly.
If you're looking for strange things anyways...Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
11steve-
Just found this thread and wondering if you ever found a fix. I also have a Peachtree DAC-iT and run JRiver to the X1 asynchorus (sp) convertor via usb from computer and then coaxil into the DAC. Do you have any static electricity issues in your listening area? I have found in my system that while running jriver I get skipping every time I get up from the couch and touch anything metal in my system. Even walking across the area rug between couch and entertainment system will apparently send a surge that the 2ch system is picking up. Right now I have the usb cable from the computer running under this rug and am hoping to eliminate that issue when I reroute the 20' USB cable down into the crawlspace and back up into the living room, but I think I will still have issues with static electricity discharges regardless. For now I just touch the side of the stove before touching any of my audio gear.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
I had the issue with the Peachtree on digital IC but never toslink, and i never tried USB.My Keces has never had the issue in the month plus I have had it in my system.Polk Lsi9
Keces DA-131 mk.II
I had the skipping issue when I first started in on computer music. I was using an older windows laptop. I then switched to a newer iMac and haven't had a skip since. Not one in hundreds of hours of music. Also using a Peachtree, the Dac it x. Not saying it's your computer, but it might be.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
11steve-
Just found this thread and wondering if you ever found a fix. I also have a Peachtree DAC-iT and run JRiver to the X1 asynchorus (sp) convertor via usb from computer and then coaxil into the DAC. Do you have any static electricity issues in your listening area? I have found in my system that while running jriver I get skipping every time I get up from the couch and touch anything metal in my system. Even walking across the area rug between couch and entertainment system will apparently send a surge that the 2ch system is picking up. Right now I have the usb cable from the computer running under this rug and am hoping to eliminate that issue when I reroute the 20' USB cable down into the crawlspace and back up into the living room, but I think I will still have issues with static electricity discharges regardless. For now I just touch the side of the stove before touching any of my audio gear.Loud & Clear wrote: »I had the skipping issue when I first started in on computer music. I was using an older windows laptop. I then switched to a newer iMac and haven't had a skip since. Not one in hundreds of hours of music. Also using a Peachtree, the Dac it x. Not saying it's your computer, but it might be.Polk Lsi9
Keces DA-131 mk.II
