Best-value / most-bang-for-the-buck Mods for Monitor 7's
SingleMaltKing
SingleMaltKing Posts: 19
edited May 2014 in Vintage Speakers
The prodigal son has returned to Polk-dom after decades of being away. Am returning slowly, with a pair of Monitor 7's a pair of 4's.
Question to this group about the Monitor 7's - what are the most value-oriented mods? Crossover upgrade? New tweeters? ...
All thoughts welcome.
Post edited by SingleMaltKing on
  • SingleMaltKing
    edited April 2014
    Thanks, ZLT. And of the two, which should be done first (assuming can only do one right now)? If the tweeters, what is the recommended tweeter?
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited April 2014
    That depends on what type you have now...
    Can you post some pics, or do you know which model you have?
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited April 2014
    Dynomate the drivers is a cheep way of tighting base.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • xjghost
    xjghost Posts: 1,115
    edited May 2014
    Is this with all Monitors? I have been searching for a thread with links to other threads with upgrades and pictures but have not found one. I've seen people say install hurricane nuts and Dynomate the drivers but would like to see what people are talking about.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • gmjungbluth
    gmjungbluth Posts: 232
    edited May 2014
    I would say that the most value-oriented mod you can do is preventative maintenance.
    The mid-woofers on the Monitor series are prone to magnet shift due to the failure of the epoxy holding the magnet in place around the voice coil.
    Get some good aftermarket epoxy (I used JB Weld) to seal the magnets in place and prevent the loss of one of your drivers. This should cost you no more than a few dollars in epoxy costs.
    There are numerous posts on this forum outlining what to do if you have questions.
    Other mods I would recommend (in the order I would recommend them post-epoxy):
    1. Seal drivers to cabinet - use gasket foam.
    2. Replace crossover capacitors
    3. Replace crossover resistors
    4. replace tweeter (if SL200o or 2500 to RDO-194 or -198. Keep a Peerless if you have it)
    5. Dynomat or other sound-deadening materials on the baskets of the mid-woofer and passive radiator.
    6. Hurricane nuts, Larry's rings or other method of safely tighening seal between drivers and cabinet
    7. Improved sound deadening foam on sides of inside of cabinet
    8. Re-seal cabinet seams inside.
    And for aesthetics:
    9. Re-veneer cabinets
    10: Put in new binding posts and wire.
    I did most of this to my Monitor 7As. They turned out great. You can find my posts on my work here on the forum and on my blog: silverfacestereo.wordpress.com.
    Good luck!
    G
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • trav0810
    trav0810 Posts: 1,056
    edited May 2014
    What model of 7's do you have? If they have the Peerless tweets, I wouldn't be pushing for new tweeters. If they have the 2000's, the RDO tweeter upgrades will provide instant value.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
    F1nut Posts: 51,944
    edited May 2014
    It's called DYNAMAT Extreme....geesh!
  • teekay0007
    teekay0007 Posts: 2,288
    edited May 2014
    Geesh is right! Actually, it's called Dynamat XTREME! ; )
    The Wedge Pak (18" x 32") goes a looooonnnnnngggg way - had enough to do all midwoofers and passive radiators in my SDA-2Bs, Monitor 10Bs, Monitor 5jrs and Monitor 4s. Now, less that $25 on the 'bay: http://www.ebay.com/itm/Dynamat-10425-18In-X-32In-Xtreme-Wedge-Pak-General-Application-W-Self-Adhesion-/231236999872?_trksid=p2054897.l4275
    F1nut Posts: 51,944
    edited May 2014
    teekay0007 wrote: »
    LOL....got me. :redface:
