Major bug with forum
BlueFox
For whatever reason, this forum has added a major bug in the last few days, or it has just become exposed. Using either an iPad or iPad mini, when doing a Reply With Quote and then Advanced the display becomes very narrow instead of full screen. This is in the Test mode of operation.
This is in regard to the thread about 5 speaker jumper comparisons.
http://www.polkaudio.com/forums/showthread.php?160408-Five-Speaker-Jumper-Comparisons-For-The-SDA-SRS-1.2TL
It appears related to the embedded image in post 128 by Zltful.
http://www.polkaudio.com/forums/showthread.php?160408-Five-Speaker-Jumper-Comparisons-For-The-SDA-SRS-1.2TL&p=2041112&viewfull=1#post2041112
This image is full screen wide while the text boxes are narrowed to the left side.
Post edited by BlueFox on
So....are you asking for someone to fix known issues with the forum ?
Good luck on that.HT SYSTEM-
lsi 9's -
Hello,
I'll send this to Polk's IT department.
Regards, Ken -
Yup very annoying...For whatever reason, this forum has added a major bug in the last few days, or it has just become exposed. Using either an iPad or iPad mini, when doing a Reply With Quote and then Advanced the display becomes very narrow instead of full screen. This is in the Test mode of operation.
This image is full screen wide while the text boxes are narrowed to the left side.ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
