Rotel RCD-855 CD Player Error Message
stretchl
stretchl Posts: 1,334
edited April 2014 in Electronics
Any thoughts from anyone on why I might suddenly be getting the "ERROR" message on all CDs?
Thanks.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
    F1nut Posts: 51,896
    edited April 2014
    Could be a number of reasons, the most likely being the optical pick up has failed or it could be a logic board failure. Can you hear the CD spinning?
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2014
    That player is about 24 years old at this point it is probably running on fumes. Time to let it go. If you want a Rotel that will match it and probably last just as long get the RCD-1072.
    edited April 2014
    stretchl wrote: »
    Thanks.
    Bad whiskey ??
  • embrown057
    embrown057 Posts: 46
    edited April 2014
    That should be a easy fix. That transport uses a very common Sony KSS-213C. They are inexpensive and very easy to replace. B&D enterprises should have them in stock, ask for Bud. Try to avoid purchasing one off of EBay if possible, it's a real crap shoot to get a good one. While your in there replace the belts. P.S. Don't forget to remove the ESD solder jumper on the laser. Always use a ground strap while working on the laser.
    edited April 2014
    I don't know if that particular player is even worth the expense or time put into it. With many good cdp's out there these days on the used market, a hundred bucks can buy you something just as good if not better.
  • stretchl
    edited April 2014
    Thanks, everyone. Any thoughts on the OPPO DV-980H for sale here in the forum?
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    edited April 2014
    BTW, Tony, the Tattered Cover bookstore in DT Denver is a great place to hang out for a while. Wahoo Fish Taco's are amazing, also.
    - Isaac Asimov
    Hi-Fi
    Visuals
    pitdogg2 Posts: 27,184
    edited April 2014
    stretchl wrote: »
    yep fish tacos that is why I went for the taco's.....bet they are just scrumptious after the FIRST store visit....:lol:
    edited April 2014
    You guys telling me a bookstore....has great fish taco's ? A bookstore ?? Seriously ??
  • chumlie
    chumlie Posts: 8,658
    edited April 2014
    stretchl wrote: »
    Good deal for the price.
