Can you use Polk 4 Shots on the PC (Splitter?)
SoleSky
Would a 3.5 mm splitter that splits audio and chat work for the 4 Shot? Could you send me a link of the splitter if so? Thanks!
http://www.amazon.com/2-5mm-Mobile-Headset-To-Converter/dp/B000IZCUTQ/ref=sr_1_3?ie=UTF8&qid=1396486229&sr=8-3&keywords=headset+to+pc+adapter
Maybe something like this doo-dad?
Post edited by SoleSky on
That's close, but you need it to be 3.5 female (that one was 2.5 female)
Try that, then you run one 3.5 mm cable to the mic input on your PC and another to the headphone out.
http://www.ebay.com/itm/3-5mm-Stereo-TRRS-4-Pole-Plug-to-3-5mm-Mic-Headset-Jack-iPhone-Audio-Adapter-/290850677148?pt=US_Cell_Phone_PDA_Cables_Adapters&hash=item43b80d219c -
My bad haha! Have any of you tried it with success?
http://www.amazon.com/Smartphone-Headset-PC-Adapter-01-PH35-PC35/dp/B008OB2NHA/ref=sr_1_1?ie=UTF8&qid=1396556463&sr=8-1&keywords=headset+to+pc+adapter
Here we are, this should be correct. I'm going to buy it and try it out. Thanks for your help. -
Any newer computer within the last year should include the correct port. I know my laptop has both but if you connect it to the headset port it works for both. You may want to just try and see what happens.
I wonder is this below will work:
http://www.turtlebeach.com/product-detail/cables-parts/ps3-pc-chat-adapter-cable-amigo-ii/118 -
.macscomp68 wrote: »I wonder is this below will work:
No. -
I tried the splitter with the polks and it does work. Now, I'm not sure if that's because the computer is new or if it will work on any PC.
sorry need 10 posts
This is compatible with Xbox One, smartphones and tablets. You can also take calls with the touch of a button.
