Looking for recommendation on a receiver for RTi10 for music
IamNotRichard
IamNotRichard Posts: 5
edited April 2014 in Speakers
Hi, I would like to use two RTi10 speakers for a 2.0 setup for music. Would any of the following stereo receivers would be a good match: Onkyo TX-8050, YAMAHA R-N500, Denon DR-AN5? Any other receivers I should consider?
Also, am I right to assume that getting a 2 channel receiver is better than getting an AVR in the same budget range?
I have heard comments that the RTi10 are more on the "bright" side. I assume I should look for a receiver more on the "warm" side??
Thanks for any comment!
Post edited by IamNotRichard on
    F1nut Posts: 51,703
    edited March 2014
    Even better if you're looking for a one box solution, get a good integrated amp.
    What is your budget?
    IamF1nut
  • IamNotRichard
    edited March 2014
    Ideally, I would like to limit the budget to < $450. Also, if possible, I would like networking capability, as I would like to play music files off the network drive.
    F1nut Posts: 51,703
    edited March 2014
    Sorry, can't help you with that stuff.
  • drummer86
    drummer86 Posts: 441
    edited March 2014
    Also, am I right to assume that getting a 2 channel receiver is better than getting an AVR in the same budget range? !
    I'd say no. AVRs will have better connectivity, room correction, and features. The sound quality won't likely be different in that price range.
    Either of these should do
    http://www.accessories4less.com/make-a-store/item/yamrxa810bl/yamaha-rx-a810-home-theater-receiver-networking-3d-ready-hdmi/1.html
    http://www.accessories4less.com/make-a-store/item/onktxnr717/onkyo-tx-nr717-7.2-ch-thx-certified-network-a/v-receiver/1.html
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • IamNotRichard
    edited March 2014
    Thanks Drummer86 for the suggestions. I do happen to own an Onkyo717, set up for the TV. When I first hooked up the TSi10 (in theden as a separate zone), the sound wasn't too good. I could hear the full range and there is good level of clarity and details. But something seems to be missing - the sound is a bit sterile. Not really much of an audiophile myself, I am not sure if this is what some people talk about the speakers being on the "bright" side. That is why I am thinking of trying out a different amp. But, granted, I have not had the time to fully experiment with AVR settings, speaker placement etc on the current setup. Guess I need do that to see if the sound somehow can be improved. Or maybe it is a limitation on the speakers. These are a few years old and I have not heard them before.
    pitdogg2 Posts: 26,970
    edited March 2014
    Bright = lots of treble sizzle Warm = good clarity in treble region no sizzle.
    You really need to get in the receiver and run whatever it has for room correction and them play with that. Placement is another.
    TSi and RTi are two completely different sounding speakers...
    what you feel you might be missing is the bass which is not to happy with under powered speakers
  • IamNotRichard
    edited March 2014
    Yes. I was thinking one other reason for the poor sound could be due to a lack of power. I last connected the RTi10s to the Onkyo 717 AVR's Zone3 terminals. The sound might be better if I could connect them in a bi-amp setup. That is not an option with the Onkyo 717 as I use that with the TV. That was another reason I was thinking that maybe a dedicated stereo receiver might be better in providing more power, and consequently better sound.
  • Hermitism
    Hermitism Posts: 4,323
    edited March 2014
    Don't bother bi-amping using the AVR, it doesn't really accomplish anything because of the shared power supply. Current is just as important as the wpc.
    msg Posts: 10,452
    edited March 2014
    Rti10 speakers need some pretty good power to make them sound good, in my limited experience, anyway. I just went through this with those speakers and with various AVR's, amps, and different sources, though nothing high quality on the source side. Same as what you're saying - something missing. Best result I got was with an old set of separates from B&K - an MC-101 preamp with EX442 amp at 200wpc. Only with this stuff and some minor tone adjustments was I able to get relatively fuller sound. I was able to get okay results with a cheap Pioneer VSX AVR with the "sound retriever" function turned on, but I wasn't able to get those speakers sounding the way I wanted for serious listening sessions. Good for tv and background music, but made my ears bleed for extended music listening. Adding a CSi5 center and playing in surround mode helped a little, but yeah, that setup wasn't very comfortable I'm afraid to say, at least not in my case with everything I tried. Your mileage may vary. Maybe check to see that those receivers have amp preouts and add a 2ch amp down the road a little, and plan on using the sound enhancement functions in those receivers, if any, and dial back the treble a couple of notches. Or sell those speakers, and try something different if they don't work out.
  • IamNotRichard
    edited March 2014
    Hermitism, so doing bi-amp with the AVR won't help much? I am relatively new to all this. That sucks.
    msg, yeah, I was thinking about using the pre-out with another amp too. I'll experiment a bit, though I am not as fortunate as you with available resources. And as you suggested, if in the end, these speakers don't work out, I'll get something else. These speakers look quite stately, but the size is a bit overwhelming for my den anyway. They probably would work quite well as fronts in a home theater.
  • eclypse
    eclypse Posts: 595
    edited March 2014
    If its got to be a avr for now atleast get one with pre-outs so u can later add seperate big 200-300+ amps to power front 2 channels.
    Those speakers will need big power to mellow out and get ride of the bright sound.
    Most avrs today dont have pre-outs so make sure or u will be buying another receiver in the near future.
    Emotiva makes a good processer that has everything one would need and pre-outs u would just need seperate amps to drive the speakers.http://shop.emotiva.com/collections/processors/products/umc200
    Find one used for around $4-500 with tranferable warranty.
    Presonally i'd get a used amp that does 300 watts+ in 8 ohms.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    msg Posts: 10,452
    edited March 2014
    oh, don't get me wrong, man, I'm not made of money :) - I didn't have those AVR's or any of that other stuff on hand - those high end AVR's were individual purchases that didn't work out and ended up going back to the shop, unfortunately. it was more a broadsword chop to see whether a high end AVR would solve my problem - it didn't. Instead, I ended up piecing my system together with used equipment purchases, mostly, all from Audiogon, Ebay, and Craigslist. I went with separates. took me a while, and it was a maddening few months trying to sift through all the information and make decisions without opportunities to listen.
    you can totally start off with an AVR, but I think the idea everyone is conveying is that any AVR won't properly push those speakers to their potential. don't be discouraged though - start off and see for yourself. you might find that it works well enough for your needs. I say, since you already have the RTi10's (?) go ahead and do your research and check to see if any of those AVR's offer preouts (for later), and see how things work out. you might find that you like them just fine. you can add an amp later, and this would at least get you started. never know, you might be completely satisfied and done!
    if not, down the road...
    like the guys suggested, you can find a nice powerful amplifier used, with a little patience. any equipment you buy will carry over and be usable with any speakers, generally speaking, but not necessarily if you're very particular about sound. buying used will also let you get more gear for your money, and you could step up into higher quality stuff.
    howeverrrrr, if you're seriously into music and are super picky, you might consider the separates route and start looking seriously at stuff designed specifically for music. personally, I feel that you can get reasonably acceptable results with an AVR, amp, and using the system effects to your benefit, providing you're not a purist. I have tremendous respect for these guys and their wealth of knowledge, but for my listening practices, I prefer to have systems that work with mobile devices and digital sources, etc., and I have to give up some fidelity here. this is a trade-off I've mostly accepted. these don't necessarily *have* to be mutually exclusive, but they seem to be when you're first starting off, at least in my relatively limited experience so far.
    I only have a few pieces that are new. There are some really good people out there, and also some dirt bags, so be careful. most of the good guys won't try to push their stuff on you, and will be forthcoming with info and recommendations. these guys are typically very enthusiastic about the hobby and many will truly enjoy sharing what they know, whether you buy their stuff or note. talking to a lot of different people will do two things - 1. overwhelm you (experience talking) 2. help you figure out what you need/want to suit your needs. many selling equipment will offer to demo the stuff for you before you buy, at least the local ones. doesn't mean that those that don't are out to screw you, though. anyway, just a heads up on what to expect if you delve into that.
    yes, those RTi series speakers do look very nice. I really struggled with the decision to move on, and kinda miss mine at times. I'd just sit and look at them sometimes, hehe, but I had to let them go. they just weren't right for my needs, and I was driving myself nuts trying to find gear that would make them produce the sound/response I was after when their inherent design is primarily HT. It was just easier (cheaper) to change speakers, reassess my goals, and adjust my equipment direction a bit.
    to confirm, no, bi-amping doesn't work in the sense advertised by the AVR manufacturers :) I tried. even after most here said it wouldn't work :) I needed to see for myself. I really don't know why they recommend that. anyone who tries is going to notice that it doesn't really sound any different. whether they admit it or not is another thing entirely.
    sorry man, got kinda wordy, but I totally get where you're at, and it can be a bit daunting and frustrating getting started, but it's doable. hopefully, the madness won't consume you and you'll settle in to whatever system you put together and enjoy your experiences with it :)
  • PSOVLSK
    PSOVLSK Posts: 5,372
    edited March 2014
    anonymouse wrote: »
    My reco:
    - Get an older pre-HDMI receiver with preamp outputs. If you shop wisely, you can land a quality one of the older Sony ES series, or an older Harman Kardon or Denon for $100
    - Get a solid entry level older amp, like the Adcom 555 II for around $300 to 350
    - For your music streaming needs, get a separate streamer - there are so many to choose from.
    +1. I have an H/K7300 that's a beast, but I probably couldn't get $200 for it so I just keep it...just in case I need it sometime. Something like the 7300 could drive the 10's without an amp.
    msg Posts: 10,452
    edited March 2014
    actually, that HK7300 sells for $250+ regularly on Ebay :)
    I stumbled across that unit several weeks ago and was interested in finding one, but they kept sellingor were a little beat up. I'd love to hear one. agreed, beasts, and had great reviews.
    thing retailed for what, $2300+?
  • MADGSF
    MADGSF Posts: 603
    edited March 2014
    You will need more than power to tame the brightness of the RTi-10. I have plenty of power and they are still too bright for me. Something from HK might help as they are on the warm side in general. For me I would move on but don't have money for new speakers and if I did it would most likely be LSiM 703 or 705.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • drummer86
    edited March 2014
    Some of those older HK receivers are powerhouses. I have a 635 that weighs no less than 45 lbs. 75wpc 7 channels driven. $1300 new in 2004, got mine free in a dumpster two years ago. It'll drive the snot out of anything, including some big 4-ohm bookshelves I had from a friend for a while, without breaking a sweat.
  • amb426amb1
    amb426amb1 Posts: 148
    edited April 2014
    I have the Onkyo TX-777, 135 watts RMS driven into 2 channels, and when I switch to my Sansui AUD-11 ii which is 130 RMS its like night and day for two channel music. Huge Toroidal power supply with beer can caps. I use the Onkyo for HT only. i also picked up a parsound hca-1200 last week on ebay for $260 for its common ground feature to use with some SDA speakers I picked up. So far its been a cheep power house with nothing but good clean power.
    msg Posts: 10,452
    edited April 2014
    that's a STEAL on that amp!
  • amb426amb1
    edited April 2014
    msg wrote: »
    Yeah with shipping came to $325 and from the original owner. So far very happy with the sound. A lot like My higher end Sansui amps and integrated pieces I tend to lean towards for sound.
    msg Posts: 10,452
    edited April 2014
    very nice.
    great to see these deals being had from time to time. Those amps and the HCA-1500 can go for up to $500 apparently. how long had you been looking? sometimes you have to be patient on this stuff, I'm finding, and then deals pop up. this is really difficult when you're ready to build out.
    IamNotRichard - if you didn't already know this, you could do a search on Ebay, and save the search and it will notify you by email when items matching your criteria come up. I didn't know how to do this until another audio person told me how.
  • amb426amb1
    edited April 2014
    msg wrote: »
    very nice.
    That's the funny part. After getting the sda's I figured out my Sansui B2101 Amp was non-common ground unit and I did some searching for a equivalent powered unit with what I thought would fit my sound preference. Then I searched for Parasound and pulled the trigger on the 1st 1200 that looked like it had a good history.:
    msg Posts: 10,452
    edited April 2014
    man, that was lucky. I had a look/wait a while for mine.
