USB cable from computer to pre_amp?
Tom Dielen
Would it be better to use the usb audio out from my computer rather than the 3.5mm audio out?
The distance from my computer to the pre_amp is 15'
Post edited by Tom Dielen on
Not enough info for someone to really answer your ?
like what pre-amp are you using? is their a dac (digital analog converter) in your pre-amp?
does it have Digital inputs? like usb -coax - optical? because to use the usb connection you would have to load a driver into your pc that is normaly supplied by the maker of the dac for this to work. then your pc could connect this way and the pre-amp/dac would just be a new sound card for it.
and welcome to the forum!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
USB, coax digital, or fiber digital is most likely going to be better than any digital to analog conversion done in the computer!
