LED bulbs - need source
dragon1952
dragon1952 Posts: 4,932
edited March 2014 in Electronics
Does anyone know a source for the mini LED bulbs like the ones found in audio gear (like on/off indicators). 12V DC with 2 leads, they are probably about 7mm in length and maybe 3mm in diameter.
Post edited by dragon1952 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2014
    Maybe Digikey?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited March 2014
    Try this guy... he makes them
    http://stores.ebay.com/quacoaudio/
    Garage | Polk Monitor 5B's
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited March 2014
    just make sure the led says it is rated for 12volts and has some form of current limit resistor, most don't unless stated.
    did you have one fail or just looking to upgrade?
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
