Atrium 5 / Atrium Sub10 Amp Recommendations?
stretchl
stretchl Posts: 1,334
edited March 2014 in Speakers
Getting ready for summer here even though the highs are still in the 40's.
I've never used a subwoofer and never set u an outdoor system, but I bought the Atriums at the friends and family sale and now I need to power them.
I'd appreciate any suggestions for an inexpensive amp and guidance on the set up.
Thanks very much.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
    tonyb Posts: 33,072
    edited March 2014
    cheap receiver off craigslist....
  • stretchl
    edited March 2014
    With the subwoofer and 2 speakers can it be a 2 channel receiver, or do I need a HT receiver, ie. 3.1, 5.1, whatever.1?
    Thanks very much.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • PSOVLSK
    PSOVLSK Posts: 5,382
    edited March 2014
    Depends upon how the subwoofer hooks up. I would assume you could use speaker level connection and use either a 2-channel or HT AVR.
  • stretchl
    edited March 2014
    OK, cool. I'll break out the sub and... gulp... read the instructions!... this weekend.
    Any advice on speaker wire for outdoors?
    Thanks!
    - Isaac Asimov
    Hi-Fi
    Visuals
    tonyb Posts: 33,072
    edited March 2014
    stretchl wrote: »
    Thanks very much.
    I believe with that sub, you'd need a subwoofer output. Some 2 channel receivers have them, some don't. In any event, a 5.1 receiver will and any of the older robust models can still be had on the cheap.
    EndersShadow Posts: 17,704
    edited March 2014
    stretchl wrote: »
    Thanks!
    What sub did you buy? Some you can connect the RCA's straight to it for Left/Right and then use the crossover in the sub to send the some to the sub some to the speakers. Some you cant and then you would need to use a HT AVR w/ sub out.
    Speaker wire for outdoor I would probably use some in-wall rated cable so anything CL rated. You might even be able to use cable normally used to power exterior lights for your use, but it may be hard to tell the polarity at each end if you dont mark it.
  • stretchl
    edited March 2014
    It's the Atrium Sub10.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • rooftop59
    rooftop59 Posts: 8,121
    edited March 2014
    Ok so just read the info on the Atrium sub10 and it looks like it is unpowered built has a built in 150 hz low pass filter (i.e. crossover). So that may make it a bit more complicated...
    Game Room 5.1.4:
    Bedroom 2.1
  • stretchl
    edited March 2014
    Looks like I need to get my read on before summer comes. Of course, since I live in central Illinois, that gives me about four months or so. :(
    - Isaac Asimov
    Hi-Fi
    Visuals
