Looking to upgrade HT setup.
Hi all,
I currently have Klipsch ksf 10.5's for fronts, and matching center and surrounds. Have had them for years. Have been looking at the older RTI series and the newer RTiA series. Will be used for 75% tv/bluray 25% music. My room is 14x21. 8 foot ceilings. I know I need to listen to them first, but was hoping to get steered in right direction.
My gear:
Panny st65
Pioneer Bdp-23
Yamaha rx-a1020
Carver av-705x
Klipsch sw112 sub
My gear:
Panny st65
Pioneer Bdp-23
Yamaha rx-a1020
Carver av-705x
Klipsch sw112 sub
Post edited by Hedco on
Do you have a budget in mind?
And would it be for a total 5.1 replacement to your Klipschs?
Budget is around $1200 for front 3. Will get surrounds later.
Will be replacing klipsch. They will go to basement setup. Xbox, DVD, Wii for kids and me. -
Pair of RTI A7, Polk E-bay, for $400 each.
CSI A6, amazon, #350.
You Yamaha should be able to drive them fairly well. -
Stats on the older Klipsch 10.5 for comparison
BUILT UNTIL
1998
KSF 10.5: Specifications
FREQUENCY RESPONSE
36Hz-20kHz(+-)3dB
POWER HANDLING
100 watts maximum continuous (400 watts peak)
SENSITIVITY
95dB @ 1watt/1meter
NOMINAL IMPEDANCE
8 ohms
TWEETER
K-97-KV 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN
6" square 90(o)x60(o) Tractrix(r) Horn
WOOFER
Two K-1063-KV 8" (20.32cm) Poly cones
ENCLOSURE MATERIAL
Medium density fiberboard construction (MDF)
ENCLOSURE TYPE
Bass reflex via rear-mounted port
