Need sharp carpet spikes for LSIM 705s
Noticed that no matter how much I try to lower my spikes I cant get good contact to the floor and my speakers are not stable. I need sharp carpet spikes for my 705s. wouldn't take much of a hit from my 5 year old son to knock these babies over where they are now. The right speaker is right in the walkway into the living room.
What size and where to buy please?
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Post edited by eclypse on
They should have come with skinny sharp spikes.Political Correctness'.........defined
President of Club Polk -
Breaking that carpet backing can be tuff. Depends on whats underneath that carpeting and if you care about the wood floor under the carpet. Concrete under, I'd just use a nail to puncture a hole in the carpet. The spikes will leave marks once you move the speaker.
If your worried about the wood floor under the carpet, then maybe adding a granite or wood slab on top for the spikes to sit on is a better approach. Some even claim better bass response that way too.HT SYSTEM-
lsi 9's -
Not sharp enough obviously. Had ni probs at my condo prior. Speakers fit solid like a tank. Thats a good idea with the nail.. will try that. No idea whats under rhe carpet but dont think its hardwood. I've used stone slabs in the past thst are 12x12 but these speakers are much longer.. have to measure.but dont know If 18" squares would work.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
18" slab would work but with the speaker near a pathway i want them firmly on the ground so first ill try a thick nail to peirce the carpet backing.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
skinny yes but dull tipped. Thought about shaping them but crap that would take forever with 8 of them haha.They should have come with skinny sharp spikes.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
http://www.adonacorporation.com/tweaks.html
some nice sets here all about the price of anyplace else. I've used these and they pierce carpet very well
Large Brass Cones- Black-chrome, Chrome, Black :
Solid Brass Gold Extended Cones
Gold Slender Cones in 1/4-20
these caught my eye..Adjustable Brass Cones with Lock-nut:
madisound has the same just seen and cheaper
http://www.madisoundspeakerstore.com/tiptoes/feet/feet-yung-yblc-black-chrome-tiptoe-2.15/
http://www.madisoundspeakerstore.com/tiptoes/feet/ -
Nice carpet spikes!
And ideas for some nice binding-post jumpers?
http://www.dedicatedaudio.com/inc/sdetail/115/4254
Douglas Connection will also provide custom jumpers
You can also PM him "helipilotdoug" as he is a forum member here and a stand up guy2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
MIT also offers jumpers, the new StyleLine and the tried and true Shotgun version. www.mitcables.com
BTW HDTVAV, they are simply called spikes as they can be used on any surface.Political Correctness'.........defined
