FS: Audiosource amp / preamp
RuSsMaN
RuSsMaN Posts: 17,986
edited July 2004 in Flea Market
Audiosource Pre One A. Tons of inputs, two phono stages, two sets of outputs, subsonic filter, bass eq (+5db @50Hz), tone controls, the usual bells and whistles.
Great overall condition, a little rack rash on top - very minor.
Audiosource Amp100. 50w cont / ch, bridgeable to 120 (actually did 62w / 137w on the bench). Front mounted gain and balance control (could be used as an integrated alone). Has 2 inputs, with a selector for 'override'. Meaning if it gets a signal on both, input 2 will override input 1. Also has a separate line out to daisy chain to another amp. Has selectable 'auto on' function, if you want it to turn on when a signal is present. Will run 2 pairs of speakers, 4 ohm stable. Binding posts for speakers.
New condition, with original box. I bought it new, and have had it in use for about 3-4 months in the whole-house rig. I still use 2 of these amps for other 'zones'.
You can still find them on ebay for $110 or so, new if you wanted to run a pair bridged, or for multizone use as I did. (the independant gain on each amp comes in real handy for contouring the level in each zone). Bridging? Where can you get some new 120 (137) watt mono blocks for this money?
$125 + ship both peices. Pics later tonight when I get home. Great entry level separates rig, and I think the sound will suprise you, it did me.
Cheers,
Russ
Post edited by RuSsMaN on
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    Put me on the Possible list..if someone else once Wants them go ahead...
    Pauly
    Life without music would
  • MSkeezer
    MSkeezer Posts: 1,183
    edited July 2004
    Arrrgghhh, wish I had the money....
  • smglbrth
    smglbrth Posts: 1,496
    edited July 2004
    For that price it's a steal for beginning separates, bedroom, or office systems. I also had the Pre One/A but with two Amp One's, bridged, before the B&K. Did the Audiosource actually sound that much worse than the B&K? Nope, but..., they are in a different league.
    Hat's off to you Russ for selling at such a good price, fellow Polkies are awesome aren't they?
  • Early B.
    Early B. Posts: 7,900
    edited July 2004
    I'll take 'em. Russ, PM coming your way...
    "God grooves with tubes."
  • stereo55
    stereo55 Posts: 418
    edited July 2004
    If for some strange reason this deal is ongoing later on (someone backs out) and the set is still available ; please shoot me a PM .
    Much thanks , stereo55 ;)
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • RuSsMaN
    edited July 2004
    Stereo55, escrow has closed on this one. I'll keep you 'on the list' for future similar items.
    Cheers,
    Russ
