Monitor 7 Mids, One Extends more than the other?
Pauly
Pauly Posts: 4,519
edited July 2004 in Speakers
Seems like one mid extends more than the other, They have been on my HK AVR 20, My Onk 701 and fasters 2chnl rig all balanced out.....Any thoughts? Input? Anything?
Pauly
Edit,..seems like one drives more even though seems pretty even in sound???
Life without music would
Post edited by Pauly on
  • scottnbnj
    scottnbnj Posts: 709
    edited July 2004
    are you talking about what you hear from the listening position or some other position?
    and when you say 'extends' are you talking about has a wider dynamic or tonal range? or image extends further outside or to front and back of the speak? or the driver looks like it physically travels further in and out while playing?
    for trouble shooting, you might try to listen in mono, switch l/r wires to r/l speaks, physically switch r/l speak to r/l positions and change wires l/r to r/l.
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    Driver physically extends more than the other....
  • faster100
    faster100 Posts: 6,124
    edited July 2004
    when you put the power to those 7's that one mid range pumps like its fixing to have a heart attack... seems like a worn out driver, but i know nothing about those drivers or any others for that matter, I know it doesnt look right. Hope someone can chime in and help.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2004
    Sounds like either the cab isn't sealed as it should be, or the spider on the driver itself has lost it's rigidity (is that a word?).
    I'd hope for the earlier, but more than likely it's the latter. If that thing is really moving, the voice coil is probably leaving the magnetic gap, which will lead to excessive heat on the coil, and eventually it will be toast.
    Cheers,
    Russ
  • gidrah
    gidrah Posts: 3,049
    edited July 2004
    Make sure it's in phase.
    Make it Funky! :)
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    OK on one Mid it says "Polk" and the other "RR 602" is this a replacement? The RR one. This is the one that "extends" more.
    Let me know
    Pauly
  • scottnbnj
    edited July 2004
    that would drive me nuts. even if i had to struggle to hear the difference, i would still constantly struggle to hear the difference.
    the same thing happened to my monitor 7b's (well, i did it to myself). it ultimatly led to lsi9's.
    got a replacement driver off of ebay, it was physically different, i figured i could go buy a new matched pair of drivers or cut my losses and buy new speaks.
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    u cant really tell the diff other than looking at the driver itself
    mhardy6647 Posts: 34,993
    edited July 2004
    If I understand correctly, one of the drivers is 'fluttering' (excessive cone movement). In the old days, this was often 'rumble' (very low frequency noise) from a turntable or record, or some very low frequency vibration (e.g., footsteps) being picked up by a phono cartridge, transduced to the amp, and duly amplified and reproduced. Of course, most folks here may not even know what a 'record' or 'turntable' is :-)
    So... assuming that no turntable is present, here's another suggestion... there could be some low frequency (or even sporadic DC pulses) being generated by the amplifer itself. This is easy to test. Swap the 'bad' speaker and the good one in your system. See if the flutter follows the speaker or the amp channel. If it is the latter, you've got eletronics trouble brewing. Modern amps have all sorts of protection circuitry to protect your speakers from DC if the outputs short out, but nothing's perfect and IF it's the amp you'll want to repair or replace it before it takes the speakers with it when it goes south.
    Just a possibility...
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    This is why i said these speakers since i have owned them have been on 3 seperate amps and still the same...I pulled out the driver last night and it is a 6502, I however did notice that some of the screws were not completely tight and there could have been an air leak but did not retest after i re-tightend as i took out one of the tweets to put in my new pair of M 10's, will retest when i get the a new tweet from madmax and see if it was indeed not "air" tight. If not then maybe its on its last limb, though sounds fine to me.
    edited July 2004
    oops... sorry. Thought I read your post carefully, but obviously not.
