saw c/l listing for MIT
leftwinger57
leftwinger57 Posts: 2,917
edited February 2014 in Electronics
Cruising C/L I came upon an ad for audiophile cables. some multiple sets but he is showing MIT Terminators. I'm already inquiring on lenght, age and if both ends are bananas. I believe you can see they are not not pure white so some age must be involved. Is this something to consider if the price is right and the lenght is there for me. Right now I'm using Belden 10 gu white from BJC. Again if you don't know it's snowing fairly heavily in Jersey now. Not good picking weather.
http://cnj.craigslist.org/ele/4349311439.html
    F1nut Posts: 51,970
    Those are old, early versions. I'd suggest at a mininum looking for the MIT Terminator 2 with the gray boxes and cable.
  • leftwinger57
    Jesse, thanks I knew you would chime in and have an answer. Like I already said they do look old and if only he lets them go for a rediculous price I might consider it. I don't even know if the longer side I need is long enough.
