Connecting new Onkyo receiver to OLD Polk RM Series II Subwoofer
I've searched, but can't find any references to this, probably because my subwoofer is so old. (18 years old!)
I just bought a new Onkyo receiver, model TX-NR626, and I'm trying to hook it up to my good ol' RM Series II Subwoofer. Here's my problem:
- The receiver's only outputs for a subwoofer are RCA-style connections. There are a total of 4 of them; a "L" and "R" for each of them, one labeled "Pre-out Subwoofer", and another labeled "Line Out". The manual says these two outputs both output the same thing, and can be used to power two subwoofers, or a subwoofer and something else.
-The inputs on the subwoofer are the type with a plastic nut that screws onto a terminal. There are a total of 4 of them on the subwoofer: Right and Left, + and - for each.
The subwoofer has no "Out" terminal(s), nor any controls whatsoever. (I have seen reference to these things on some Polk subwoofers, while searching for my answer.)
Can this be made to work?
Any help is greatly appreciated. I really love my old Polks and want to keep using them all!
Post edited by ba58smith on
  • zane77
    zane77 Posts: 1,696
    edited February 2014
    Run the front r and l speaker outputs to the four connections on the sub and then on to the r and l front speakers
    Two Channel
  • ba58smith
    ba58smith Posts: 7
    zane77 wrote: »
    So, just to be 100 clear, treat the terminals on the subwoofer as though they are both IN and OUT?
    Can anyone else validate this approach? (Sorry, Zane77 - you know what they say, "trust but verify".)
    Thanks so much!
    Brian
  • ba58smith
    ba58smith Posts: 7
    Well, I tried that. Got no sound from the subwoofer. But when I hooked up another non-powered sub (a cheap-o Pioneer), it worked. So I guess the RM Series II needs more power than the receiver is providing. Thanks anyway!
    Can you post a pic of the back of the sub ?
  • ba58smith
    ba58smith Posts: 7
    tonyb wrote: »
    Does that tell you what you were wanting to know? There are absolutely no other markings on the entire speaker - it's just all white.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    That's a passive sub, your gonna need an amp for that. Those are left and right inputs, no outputs. I'm betting their is an internal crossover too. Your onkyo may power it but be sure that whatever channel you use, is set to full range. I'm betting that's why you didn't hear anything when you tried it. But really you are not gonna want to power that off of your receiver, It's likely to be under 4ohm anyway.
    Yeah, that's not going to work. Even if it did, it wouldn't be very good. Time to go shopping. What speakers are you planning on driving with your receiver ?
  • ba58smith
    ba58smith Posts: 7
    I'm (obviously) pretty ignorant on all this, and really appreciate your help, folks!
    1. Would it make sense to get an amp just to power the sub? Do they make such a thing?
    2. The speakers are also Polk (I've been a fan since 1989!) - but they don't need an amp, as the receiver acts as the amp for all except the sub. At least, I think that's right - they seem to be working fine. The fronts are RT5, the center is a CS225, and the rears are still in their ceiling mounts in another room, so I don't know the model number. These are all from about 1999.
    BTW, the CS225 has a bit of static out of one of its two speakers. Not bad, but you can hear it if you listen closely. Any chance it could be replaced, this many years after it was made? (About 1999.)
  • PolkieMan
    PolkieMan Posts: 2,446
  • ba58smith
    ba58smith Posts: 7
    PolkieMan wrote: »
    I'm confused about two things:
    1. Is this yours, listed on ebay, but you have decided not to sell it? Or are you saying you have one of these, which you're going to keep, and the ebay link is just to show me what you have?
    2. The input on the back is four terminals - L/R/+/-. But my Onkyo receiver has only the RCA-style outputs to the subwoofer - one cable out of the receiver goes to the subwoofer. (At least, that's how the Onkyo diagram illustrates it.) How would I connect these two devices?
    Am I better off buying a powered subwoofer with an RCA-style input, and be done with it? Polk sells a factory refurb PSW10 on ebay for $100 that looks like it would be a good solution.
  • jeremymarcinko
    Your Onkyo's subwoofer out is supposed to go to a powered subwoofer or a separate subwoofer amp.
  • ba58smith
    ba58smith Posts: 7
    I've decided to keep using the old subwoofer with the Zone 2 speakers on the Onkyo, and I ordered a refurbed PSW10 from Polk. Thanks, all, for your help!
  • ALSATIAN in USA
    ALSATIAN in USA Posts: 127
    http://www.parts-express.com/dayton-audio-spa250-250-watt-subwoofer-plate-amplifier--300-803 .... Built a little box for this and you're good to go!.... use LFE on your receiver to plate amp, plate to sub !
