Class d audio
jerseybowler
Does anyone have one of their amps? They look pretty tempting and have great reviews, although they are limited in number..
Post edited by jerseybowler on
They offer good power, but I feel their sound quality falls behind ICEpower, Hypex, and Tripath having owned all of them.
Thanks. Any experience with Peachtree 220?
I believe that amp uses the ICEpower modules which should sound pretty good.
I can vouch for ICEpower as well. If you want to DIY, check out:
http://www.profusionplc.com/pro/gex/prodGen.html?prdtyp=power%20amplifiers
The modules that start with "ALC" are Abletec which is what D-Sonic uses on their current products (except the top model... drawing a blank at the moment, but they do some mods to it beyond the bare module). D-Sonic used to do ICEpower and both their old models and new ones are solid performers.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I would pass on the brand named "Class D Audio", IMO, they give Class D a bad name.
Modified or newer ICE modules sound good, so do Hypex modules."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
