Matching central speaker for LSi9 and LSi7 speakers
inbox
inbox Posts: 21
edited February 2014 in Speakers
I am looking for a center speaker to complete my HT. I have LSi9´s front speakers and LSi7´s for surrounds speakers.
I wonder what can be better and matching with my LSi series if the LSiM704c or the CSiA6. My room is about 18x14 size.
thanks in advanced,
Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
Post edited by inbox on
  • falconcry72
    falconcry72 Posts: 3,580
    Why not an original LSi-C?
  • inbox
    inbox Posts: 21
    Does that model is not discontinued?
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
  • falconcry72
    It is discontinued, but you should be able to find a used one.
  • inbox
    inbox Posts: 21
    do you think that best option is a LSiC used one (4 ohm) than a (for example) a LSiM 704c (8 ohm)?
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
  • falconcry72
    Personally, I think the best match to your fronts is a 3rd LSi9.
    tonyb Posts: 33,065
    What are you driving all these speakers with ?
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    +1
    Best answer yet.
    To the OP, go all 4ohm or all 8ohm. The LSiC is the logical choice over your first center choices, but a third i9 would be a lock.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • inbox
    inbox Posts: 21
    I agree it would be very good option to get a third LSi9 but i think it would be so difficult to get only one...
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
  • inbox
    inbox Posts: 21
    tonyb wrote: »
    With a Sony DA2400ES (4 ohm)
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
    tonyb Posts: 33,065
    inbox wrote: »
    Friend, your seriously under powering these speakers, especially the 9'S. You need an amplifier for that many 4 ohm speakers, no receiver will be able to handle those without risks involved.
    What are you running in? 5.1 or 7.1?
    Because if it's 5.1 you could just buy a pair of Lsi-9s and use one as a center back for a 6.1 set up!
    cnh
  • jeto
    jeto Posts: 17
    Soon I will have two LSi9's for sale, Two LSI7's and One LSiC. All like new.
  • ken brydson
    ken brydson Posts: 8,980
    jeto wrote: »
    Skirting the rules there sparky...
    tonyb Posts: 33,065
    Seriously....wtf ? Comes here asking about a matching center then says soon it will all be for sale ? Maybe so....but it won't be for sale here unless the rules are met.
  • jeto
    jeto Posts: 17
    Sorry don't know what you're talking about. New here and am going to change over all my speakers. No can offer to sell stuff? If that's the case sorry I will retract.
  • jeto
    jeto Posts: 17
    tonyb wrote: »
    You all got me lost now. I will read the rules and not I repeat NOT offer the items I will be selling here on this forum. I'll do the ebay thing.
  • CCNJ
    CCNJ Posts: 384
    I used to have the LSIc and was not a big fan. The 3rd LSI9 would be a good choice as others suggested. I had the LSI9s as fronts and really enjoyed them but I did run a separate amp which is needed to make them reach their full potential.
    Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
    Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
  • mantis
    mantis Posts: 17,312
    The LSIC gets kicked around a lot in here. Not by me, I owned it and liked it very much. I had it blended into the front array perfectly with no hint of fault. I suggest getting one, there is nothing wrong with the LSIC.
    Dan
  • Inspector 24
    Inspector 24 Posts: 1,308
    LSi9 laying on it's side perhaps?
    Seems that would work well no?
    But really, a LSiX speaker of any kind will blend best with your other speakers.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Loud & Clear
    Loud & Clear Posts: 1,538
    I thought the LSiC sounded great. The LSi9 has an offset tweeter. That would probably drive me crazy if I was using it as a center. Not that I'd necessarily notice in terms of sound, but just knowing that the tweeter wasn't centered would agitate me.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Tungx2
    Tungx2 Posts: 58
    even if you get an old LSiC, you can modify the crossovers, so you don't have to worry too much about it being old. It's still a great speaker.
    TV.......................Samsung 46" LCD LN46A550
    A/V Receiver.........Yamaha RX-V3900
    Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
    BluRay Player.........Sony PS3
    Fronts...................RTia9 (modded)
    Center.............. ...CSiA6 (modded)
    Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
    Rear Surrounds.... Deciding if front presence is the way to go instead.
    Sub..................... SVS PB12-plus/2
  • inbox
    inbox Posts: 21
    I'll give some thoughts about your comments although after read you i think too that LSiC or a third LSi9 could be the best option.
    Thank you very much. I especially appreciate your help.
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
