DB840 sub in LSI15's replace the stock 8"driver!!!!!
123457
  • ematthews
    ematthews Posts: 27
    edited January 2014
    Not sure what I did but just an update. I turned off my sub and disconnected it from the entire system..Moved my connections to Full output. And moved my speakers in about
    two inches... I am getting some good sound now...
    I also switched the speakers out and tried a few others I had... And to be honest, I didn't know how good these actually were... The other two speakers didn't have as much bass and the highs were very bright... These Polk's are good!
    Trial speakers
    Klipsch RF82
    Infinity P363
  • skrol
    skrol Posts: 3,457
    edited February 2014
    Caution on sub woofer selection!
    I did not realize that Polk made an 8" DXi series until I saw their boxed DXi108 sub (it is a dvc). They also have raw DXi 8" sub (DXi804 svc and dvc) that does not show up on the web page but does appear in the DXi series Owners Manual. Here is where the confusion sets in. Comparing the specs of the DB840 svc to the DXi804 svc, as listed in each ones Owners Manuals, they look identical. However, the specs on the web site "Spec" tab for the DB840 svc are different from what is listed in its OM. Usually, I would be suspicious of the web site specs and believe the OM. However, in this case I suspect that the web is correct and the OM is wrong. I have an email into Polk CS to sort out which is correct.
    When I do a speaker cabinet simulation using the LSi15 sub cabinet dimensions and OM specs for the DB840, things don't look right. They look better when I use the web site specs.
    Bottom line, the DXi804 is likely NOT a good replacement for the LSi15 sub. Stick to the DB840.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,457
    To make things even more complicated, I have a sales literature sheet for the DB series which has yet different specs for some of the parameters while others match the OM and others match the web. Take heart, some are actually consistent across all three sources.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • mikeyb128
    mikeyb128 Posts: 2,885
    Have to agree. Did this mod with vr3 fortress crossovers, and these speakers continually blow my mind. I like them as much or more than my lsim system. My friends are always surprised that nice sound comes from a pair of polks...
    2 channel:
    Theater:
    F1nut Posts: 51,947
    Explain how a 2 ohm, 5% tolerance resistor can measure 2.5 ohm just because it is mounted in a speaker?
    This should be interesting.
  • ohskigod
    ohskigod Posts: 6,505
    Boys boys boys
    Put the soldering irons down, climb your basement stairs, walk out your front door, and get some sunshine. Lol
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Airplay355
    Airplay355 Posts: 4,298
    I just did this mod myself. I found the DB drivers on amazon for $47.50 with free two day shipping (for Prime members). I picked up two before it became impossible to find new ones anymore. So, some notes...
    I read through some posts here and saw "dental pick", so I thought GREAT idea, and bought a literal dental pick. I see now that's not what people use. Turns out, it worked really well, especially for prying out the old driver. No cabinet damage and I didn't have to unscrew the bottom plate to push the driver out. I just lifted it right out.
    I have the newer version and the grill on one speaker was so stuck on, my wife insisted that it must be glued in place. It finally came off but not without a pea sized hole in the grill cloth. Unfortunate, but this grill cloth is fragile and there really was no other way to get it off. The second grill was more loose and came out with just a tiny hole from the dental pick I used to pry it out. This hole is much more tolerable. Grills are not forever, especially the stuff they used on this series.
    I did not like the idea of mortite or some kind of messy caulk gasket. I saw someone mention cutting the DB gasket and that's what I decided to do. I used a razor blade for all the trimming. First, I cut the gasket in half, as in I inserted the blade where the driver had been and cut along the circumference of the circle so I had two circle gaskets (frontal plane, I guess?). The top part has some decorative ridges in it, so I used the bottom. There was a small ridge on the outer rim, which I trimmed off. To get this gasket to fit into the hole, I cut it again (sagittal?) so that I could lay it in the hole and overlap an area where I cut. The overlap was trimmed off. This allowed me to align 3/4 of the holes with their original position. It also kept the driver in the original position instead of pushing it farther out. I replaced the four screws that were there originally and added 4 from the DB840. I used an impact drill and the screws went in like butter without any pre-drilling.
    The VC on the woofers I got was at the bottom based on logo orientation. If mounted with the logo up, the wires were smashed against the port and I didn't want any lose wires dangling around right by the port. So I decided to invert them and just leave the logo upside down. No one is going to see it, so I don't care at all. I'd rather that than risking buzzing wires inside the cabinet.
    My port didn't seem like cardboard. It was hard and rigid. I decided not to bother with the dynamat. Since I didn't use mortite I can always pop the driver out and add it later, but for now I left it out.
    The good:
    The bass is instantly tighter. I would go as far as to say I disliked the bass from the original speaker. It was sloppy and that makes sense once I got to feel the flimsy driver compared to the stiffer DB.
    Bass is slightly deeper but not too much. Mostly I was after tighter more controlled bass. That's what I got.
    The bad:
    For those with grills that are in way too tightly, you should be prepared to ruin them or at the very least, puncture the fabric and have a hole. The only way to get the tight ones out is by pulling from underneath (as far as I can tell).
    I feel like I've made a power hungry speaker even more power hungry. This is anecdotal of course. 7guq29am547y.jpg
  • mpitogo
    mpitogo Posts: 520
    What about a DB1040 SVC for an LSi25?
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • Airplay355
    Hard for me to say. The engineers at Polk were the ones who did the work to find out the sub was a great drop in replacement. I don't think they tried it with Lsi25s. The subs seem cheap enough where you could get them, try them out and return them if you didn't like them or dump them on craigslist.
  • Hey gang, I have followed this thread for years and, considering its age, dont feel too dumb by keeping it going to ask a question now. I have loved my 15s for many years, but the one nagging thing about them (to me anyway) was the upper bass rolloff. I could never really smooth it out so I just set the receiver to a high crossover, and handed most of the work to a pair of 10" Hsu subs. That helped quite a bit.
    I listen to a lot of light strings and female vocals, so deep extension has never been a real priority in lieu of smoothness. So just recently I was considering selling the speakers just because it has always seemed like a bandaid fix.
    Burning question now to is have you guys found the upper woofer crossover smoother with the replacement woofer? Or is this a complete replacement crossover thing?
    On another note at the other end of the frequency spectrum (and unrelated) the highs seem 'capped' for a lack of a better word that I can come up with. That one I can live with for now though.
  • K_M
    K_M Posts: 1,631
    The mod, involves changing the side mounted woofer (8") that has a decent bit less upper bass boominess. It is a great change "IF" this particular issue bothers you.
    It can be also helped by doing what you do, crossing a sub fairly high, and adjusting the level to your preference. There are ways to mod the crossover to also remove the "issue" of bass boominess also.
    Not sure how to answer about the "highs", they seem fairly good as is, but not too forward like many speakers are voiced.
  • Thanks K_M, The highs shouldnt have entered the picture here as its not the topic. My mistake.
    Your description was enough for me to give this a try. I find the small Hsus blend nicely at the bottom, so that area of midrange is the only 'in my face' problem that I have that I was never able to fix.
  • Airplay355
    I found the mod helped with what I perceived as boomy bass. Extension is better, impact is better and the speaker sounds better when run full range. For HT they're crossed at 60hz so they really aren't doing much but for music, the full range abilities help out. I prefer not to use my sub with music unless I'm trying to annoy the neighborhood for fun.
    I find it to be a more cohesive speaker. I also figured that for $80, if I didn't like it, I hadn't wasted much.
    I don't have a problem with the highs at all. The tweeter is what draws me to this speaker. My wife and I were watching a movie the other day where a smoke alarm went off and we couldn't tell if it was in the movie or was our alarm. They're very accurate and extend plenty high for me :)
  • mm840lsi15
    mm840lsi15 Posts: 35
    edited December 2017
    Hi all,
    Just registered here to say that although the DB840 upgrade does make the LSi15 bass sound tight and nice, the MM840 sub destroyed the DB840 in my LSi15s with modded crossovers. Whereas the db840 makes the bass tight, the mm840 takes the bass even deeper, punchier, more dynamic and even thunderlike. I'd recommend anyone considering db840 swap to try mm840 as well. Make sure you use all 8 screws to make sure your mighty mm840 is secured tight in there.
    I should note that the crossovers in my LSi15s are modded, this is yet another way to make your LSi15s sound much better. Just in case, I drive my LSi15s with a pair of fully modded Adcom GFA-565 monoblocs.
    Cheers.
  • elmeri
    elmeri Posts: 6
    edited July 2018
    Now that DB840 is discontinued and hard to find, anyone have an opinion on using the new DB842?
    Quick look at the specs show it's slightly shallower (within 10mm), but slightly wider by about 5mm (179.4mm old vs 185mm new). Will there be an issue getting the larger subwoofer to fit in the LSi15 enclosure?
    It can handle much more power (up to 180W old vs 250W new, both continuous) and sensitivity is similar (84dB old vs 85dB new)
    Same frequency response: 30-200Hz
    Datasheets below:
    https://d3vqw2nv1topde.cloudfront.net/assets/Product Documents/Product Information Sheets/db sub infosheet.pdf
    http://www.polkaudio.com.au/uploads/files/Files/dbSub_MN.pdf
  • Airplay355
    Try it out and let us know :)
  • elmeri
    elmeri Posts: 6
    Airplay355 wrote: »
    Having used the DB840 in your speakers, do you think the increase in diameter will be an issue or is there some wiggle room? It's nominally 5.6mm larger according to the documentation.
  • Airplay355
    I'm not too sure. There might be enough room to fit the driver in the cutout of the wood paneling but maybe not in the MDF enclosure underneath. Check out the post on page 5 from mesquitehead. In his picture, you can see how much space there would be.
    I still think the easiest way to find out is to just grab one from Amazon and try it out. If it doesn't work, Amazon is very easy to return things.
  • K_M
    K_M Posts: 1,631
    I do not see the T/S paramaters listed for the new versions.....
  • aggie113
    aggie113 Posts: 9
    Just picked up a set of LSi15/LSiC to replace some RTi12/CSi A6. Already put in an order for the Fotress upgrade for all three and would love to see some update on the sub swap using one that can still be found in stock.
    In use: Polk LSi15s (sub upgrade), LSiC, LSi9s SVS PB 10 ISD connected to Onkyo TX-NR777. VR3 crossover upgrades ordered for fronts and center.
    Collecting dust: Polk RTi12s, CSi 6A, RTi38s
  • skrol
    skrol Posts: 3,457
    I had collected a as many Polk car sub parameters as I could find (see attachment). It gets a little confusing as there are some contradictions between what was on the web vs what was in the spec sheets.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • aggie113
    aggie113 Posts: 9
    Well, the DB842 SVC arrived today. Was able to take the cover off the old sub with help of a plastic spudger kit. It was glued in but once you get a small section to come out you can just grab it with your fingers around the edge and work it loose.
    Old sub came out easy enough. The DB842 fit right in, didn't have any clearance issues as far as I could tell and didn't have to mess with the plastic ring on it. Just used the original 4 screws for now. I have a MM842 arriving early next week and I'll try that one out in the other LSi15, and see which sounds better (if it also fits).
  • mdschlayer
    mdschlayer Posts: 209
    Great, please keep us posted. I am debating between DB842 and MM842 as well.
    LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks
  • aggie113
    aggie113 Posts: 9
    edited March 2019
    No clearance issues with the MM842 either. Just need to figure which is better.... wish I had better ears :)
    Did have to trim the spades off the wiring to use the spring connectors on the MM, was a tight fit getting them connected outside the box. Wasn't able to rotate to have the labeling match up, if anyone cares about that stuff.
    Post edited by aggie113 on
  • mdschlayer
    Good to hear that the dimensional clearance is not an issue. After the new woofers settle in, let us know which you prefer and sounds better. :)
    VR3 Posts: 29,535
    You guys can always mount the magnet on the outside!! :))))))
  • aggie113
    aggie113 Posts: 9
    I just went with two MM's. Have to return the other through Amazon so just figured I'd go with the higher end sub...
  • Bringing this post back from the dead...
    What specs are we looking at to make sure that these subs will work besides the physical dimensions.
    Would these fit?
    http://www.loudspeakerdatabase.com/Dayton/DCS205-4
    Audio system lost to water damage... :(
  • VR3 wrote: »
    Actually, although I know you are kidding, that would improve deep bass to some extent.
    The added "Volume" cabinet wise, with the area of the speaker and magnet reversed would help.
    God only knows why Polk had to do with such a tiny bass enclosure.
    I calculated it to be only about .7 cu ft. Most woofers this size, use at least 1.00-1.5 cuft.
    I know the answer was a narrow enclosure, but not only did we lose deep bass, but it is not all that efficient either.
  • I'm late to the party, being a new LSi15 owner. I appreciate the wealth of knowledge in this forum, that came in handy when researching various Polk options and whether to purchase the LSi's!
    I don't dislike the low-end of the LSi15's at all, but I have a subwoofer handling much of that duty, so upgrading the 8" woofers for more of that mid-pass bunch that people have described here makes sense. My uncertainty is which drivers to select, with the DB840 being long gone...
    It appears that either the DB842 ($70 ea) or MM842 ($104 ea) will fit, and both have the same VAS requirement. I figure it's worth paying a bit more for the better MM's, but I did read at least one person expressing the concern that they might not match the rest of the LSi as well as the DB, which is what Polk recommended as a replacement in the first place.
    DB vs MM: 3-7/8" vs 4-1/16" top mount depth, 250W vs 300W, 84 dB vs 85 dB, 7" vs 7-1/8" cutout diameter, same 0.66-1.2 cu ft for both (target = 0.54).
    The specs mostly favor the DB's. The MM's are a little deeper and a much wider magnet and basket, so I'm surprised they have the same VAS. Since both are a little over the ideal 0.54 cu ft, I'm thinking the more svelte DB's might suffer less reduced performance by the tiny enclosures?
    Looking at other brands, there's a pretty limited selection of shallow-mount SVC's, so there's not much incentive to risk mixing tonal qualities.
    BTW, reading through this and other old threads, I only ran across one other mention of woofer grills like mine, so I might as well add this to increase the odds of other people finding it: Mine are not the type that pry out of the wood trim. They are screwed into the back of it, so the wood must be removed from the tower. I find that rather difficult to do, as it is on too tight for plastic pry tools or putty knives. Screwdrivers were the only thing I could get enough leverage with. Fortunately, the slight marring of the finish that resulted gets covered back up by the wood.
    Polk LSi15 fronts, LSi7 dual centers, Linn AV5110 sides, Polk RT15i rears, Emotiva UMC-200 pre/pro, Carver M-1.0t MkII front & center amps, Parasound surround(s) amp, Crown XLS1502 & Dayton 18" sub, BenQ HT2050 projector.
