MM6's do not fit
denis87
Well i just went to a professional installer and my mm6's do not fit in my factory door locations. This is on an 04 civic. The only way i can use them is if i get kick panels for my civic. what do you guys suggest i do? The Q logic kick panels do not fit these speakers either. any help gladly accepted.
www.dmbvideo.com www.oilfans.com
Post edited by denis87 on
im sure you can make em fit with spacers...
sounds to me like your installer is a lazy ****
Yeah that is a major **** I have with the Momo speaker line. The basket is about the size of a football and is hard to fit in most places. However Ive seen too many custom installs to say "you cant fit that there".
First Id figure out the problem. If its too deep then look into spacers. If you have to cut out a 3/4" MDF piece as one thats fine. If it sticks out too far then you can consider cutting out the hole in the door panel and using the Momo grill.
If its a width problem then you can sut out the existing hole to a proper size. However this will make putting the stock speakers back in a ****.
If all else fails then you can look to an installer that can build you a custom kick panel that you can use. This will be a little pricey but it will work.polkaudio sound quality competitor since 2005
the speaker with the spacer sticks out too far where the panel can be put back on. there really isn't another location where i can fit it either. as for kickpanels way too much for custom ones. do you think the q logic ones would fit the mm6?
http://www.qlogic.ws/2003/products/qforms_detail.jsp?classID=57&productID=7279
here's a helpful like that describes my situation.
http://www.7thgencivic.com/forums/showthread.php?t=153831www.dmbvideo.com www.oilfans.com -
You should call or email Crutchfield. They sell both the MM6 and the Q Forms kick panels and would be able to tell you exactly if the Q Forms can be cut enough to accomidate the Momo.polkaudio sound quality competitor since 2005
Isn't there a "sheath" over the MM6 magnet you can take off?Brian Knauss
ex-Electrical Engineer for Polk -
theres a grill...is that what youre talking about?
ive also been told by Kim you can take the beauty caps off...but I dunno how you would do that on the new ones since theyre not connected by screws anymore
gonna try a different installer. word at the 7thgencivic forums is that they should fit. keep the fingers crossed.Testing
Testing
Testing -
^^^opps wrong username that's the one i usually use.www.dmbvideo.com www.oilfans.com
-Cody
They are connected by screws, but you must peel the plastic label off first. -
Does it make it shallower? If so by how much?www.dmbvideo.com www.oilfans.com
BTW how did you get that label off?www.dmbvideo.com www.oilfans.com
Approx 1/4 inch. Flathead screwdriver. You will destroy the label.
i wonder why they use that sheath or if it is suppose to protect the magnet/speaker. i think most speakers just have the magnet unprotected. thanks a lot josh (and others) this may save me from returning these speakers.www.dmbvideo.com www.oilfans.com
You definitely dont want to return them. They are awesome speakers. Theres gotta be a way to make em fit!
Although, shame on Polk for making such huge speakers and not offering a 5.25 in the Momo line.polkaudio sound quality competitor since 2005
My thoughts exactly, even though i haven't heard them yet.www.dmbvideo.com www.oilfans.com -
Ive not heard them in a car system but I have heard them countless times on the Circuit City soundboard. They are flat awesome if you listen to heavy metal. They make a good heavy guitar sound almost good enough to eat! They are my favorite speaker under $430, with the Focal Polyglass taking over from there.polkaudio sound quality competitor since 2005
Beefier = better looking
If you see the Momo sub without the rubber boot, you would definitely be surprised
Brian Knauss
that's stupid if it's just for looks. especially since that is the main complaint with these speakers with everyone.www.dmbvideo.com www.oilfans.com
Well, a lot of the great unwashed buy speakers based on which look the best. I have to admit to being guilty of it too. The new Rockford Fosgate comps look like a million bucks and youd think they would sound amazing! Focals on the other hand look **** as hell. They look like they would fall apart if anything more than 10 watts every touched them (which is understandable since they are made by the panty waist, surrender at the first shot French :mad: ) but yet they are the best sounding speakers you can get.
Same with MB Quart. They are as plain and simple as you can get and yet they are flat awesome sounding. The Reference series is still one of my favorite speakers ever, and they are boring as hell to look at. Yet the Sony X-plod speakers look pretty good and we all know how they sound.
I guess my point it that it aint a bad thing if you make your speakers look cool as long as they perform well too, which the Momos most certainly do. If they are sharp looking more people will buy them just for the looks even if they dont know the difference between a subwoofer and a capacitor.
Yes great news the speakers are in and sound awesome, especially with only about 60 rms running to them. It certainly helps to find a good installer. I like the detail definitely sounds good. tweets a little bright but i think thats a combination of breaking them in, currently under powering them, and maybe my HU (my other old car with the same HU was a little bright too).www.dmbvideo.com www.oilfans.com
If youre running them off an amp then your head unit should affect the brightness of the sound.
You can attenuate the tweeters output on the x-over to 0db, -3db and -6db. Its probably set on 0 so you should bump it down a notch. You dont want your tweeters getting as much juice as your mids cause then you will get a bright sound. High frequencies require much less power to reproduce so if both your mid and tweet are getting 50 watts each then the tweets will be much more dominant and thus brighter sounding speakers.
Try the attenuator and see what you think.
no, it's not just you, the tweets are really really bright... mine are at -6.0 on the xover and another -2 dB on the HU (way high up, ~8k and above). and it's not just my install, cause they're sitting approximately on top of my mids.It's not good, very fundamentally simply not good. - geolemon
some people have more sensitive ears than others...i can play my mm6s as loud as i can before they distort and the only time ive turned it down because it was too bright was during a lenny kravitz song
but it still wasnt that bright...it was just too damn loud...lol
yeah...im going to be deaf...
Well i just bi amped them and now have the ability to control the brightness through my HU. The tweets are my front channel and my mids are the rear channel. so whenever i feel it's to bright i fade it more to the mids. they're are also getting about 60 rms to each, 120 rms to each speaker together. once the break in grade A goodness.
:cool:www.dmbvideo.com www.oilfans.com -
youd be better off splitting the front signal, if your using a 4 channel amp, you should have to different gain adjustments, one for channels 1 and 2, one for 3 and 4. split the right signal so it goes to channels 1 and 3, and the left to 2 and 4, run your mids off of 1+2, and your highs off 3+4, this way its just front sound, not read, and your still biamping. make sure that your highs are crossed over, if the amp wont let you, use the crossover from the component set....Testing
Testing
Testing -
I have a 96 civic and it took me a few months to get the mm6's to fit in my stock speaker locatings in the front doors, but I am glad that i finally got them in because they sound great. I am not sure what the new civic look like but on mine all i did was remove the factory grill on the door panel and use cardboard to make a template of the factory grill and make a new one out of 3/4 inch mdf which acts as a spacer to make room for the depth of the mm6's. I still need to cover the mdf spacer but at least i got them in perfectly and they is just enough space to use the polk grills. I also had to cut the plastic on the door opening under the factory grill. Just take your time and you should get them in with no problem. Trust me it is very worth the effort.Testing
Testing
Testing -
What's the benefit of doing that? I understand how to hook it up.
rbarbera75 i did get them to fit with no panel modification, except shaving a little off the inside of the panel.www.dmbvideo.com www.oilfans.com -
Good job on bi-amping. Im a big fan of it.
Myself, I prefer running the tweets off the front channels. The rear channels usually have a bass boost or EQ which is more useful for mids.
I would also recommend not setting the tweet's gain a little lower than the mids. This should balance them out just right and then you can fine tune with your tweeter EQ on the HU.polkaudio sound quality competitor since 2005
actually the kicker amp i have has crossovers, gain, treble boost, and bass boost for front and rear channels. Right now for the tweeters i'm using the polk crossover with the amp crossover off and the mids are set to 70 hz hp on the amp crossover. the only thing that sucks about the amp is that it doesn't have variable crossovers. only 120hz or 70hz. Does that set up sound about right to you guys?www.dmbvideo.com www.oilfans.com
Im not familiar with the Polk x-over. Does it have dual inputs so that you can run both channels thru the Polk x-over?
Most high end x-overs have this option so that you can use the x-over when bi-amping. The reason for this is that your mids are running at full range which isnt really a bad thing, just that it would perform better if crossed over at around 3500 Hz which the Polk x-over would do.polkaudio sound quality competitor since 2005
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
