Martin Logan owners - question regarding placement measurements
dragon1952
OK...dumb question. I've got the Martin Logan Source. When they say to place the speaker a certain number of feet from the front wall (wall behind the speakers), where do you measure to, the panel or the back of the base? They don't mention this in the manual at all. I guess it's supposed to be obvious? :^ /
Post edited by dragon1952 on
From the back of the panel, according to the video on their website. I had the same question. I spent countless hours arranging my ML to get proper placement, and it makes a major difference in sound staging when u tweak em just right! Good luck!"Everything I ever did in my life worthwhile I caught hell for"
Thanks...of course now I find that in the manual. I swear I never saw that before :^ /2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
