800va Dreadnought build
VR3
VR3 Posts: 29,552
edited February 2014 in DIY, Mods & Tweaks
That transformer is a tank :)
Not quite finished yet but close, going to deaden the chassis a bit before shipping.
Post edited by VR3 on
  • VCoak
    VCoak Posts: 200
    Vr3 very nice. May I ask the cost? I sure could use one. Thx.
    mco
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
    Toolfan66 Posts: 18,189
    Very nice, you will sell a few of these. Seems a few people have been wanting them for awhile now..
  • zingo
    zingo Posts: 11,258
    Great looking transformer. Am I right in seeing all connections being handled in one multipole connector per channel?
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Trey,
    As always, well done. Great idea to use the Neutrik connectors.
    As if you don't have enough to do, now you're getting into the Dreadnought business!
    Onward and upward!
    VR3 Posts: 29,552
    Hey guys!
    Thank you!
    This is for a client using my Monastery build 1.2TL - when I do this I use shotgun style wiring for the SDA cable which translates to a 9 awg SDA cable. So IE: 1+/1- = PIN, 2+/2- = Blade
    So as you can see in the picture, each wire goes to a specific number and is wired together at the plate when we plugs them into his speakers. If he were to sell the dreadnought down the road a bridge connector would have to be put in place or the next owner would have to wire theirs the same way.
    As far as pricing -
    Plain aluminum case, the larger of the 800va transformers, NL4 connectors, tech flex, disconnects, upgraded rubber feet, dampened chassis, 1 x 15 ft 13 Awg Supra SDA Cable, engraved plates for rear, basically a drop in addition to a speaker we have already modified would be $500 + Shipping/Paypal
    If you wanted to go to a powder coated chassis and the upgraded cable it would be around $660
    VR3 Posts: 29,552
    Dun dun dun
  • george daniel
    george daniel Posts: 12,096
    Outstanding work sir!!!!!
    VR3 Posts: 29,552
    Thank you! :)
    Very nice Trey!! Did you have the box custom made?
    No I'm not going to make one, I have four of my own that I made.. LOL!!!
    I hope you at least got a little chuckle out of that.. ;-)
    VR3 Posts: 29,552
    I chuckled a bit ;)
    The enclosure is of Chinese origins, it originally was straight aluminum and I had it powder coated black. It looks mighty purdy in black though! ;)
    Thanks again guys!
    F1nut Posts: 52,008
    SiliconRay?
    VR3 Posts: 29,552
    It was an EBay seller, took a while to find a chassis that fit the dimensions I needed.
    I drilled out the NL4 connections, that wasn't factory.
