Fabric relpacement/ SRS's
drumiv
I saw the thread on replacing the fabric on a set of 1.2 TL's. Is it safe to assume it's the same for 1.2's?
Post edited by drumiv on
It is, This is the closest thing I've found to the original cloth http://www.parts-express.com/mellotone-premium-black-speaker-grill-cloth-yard-64-wide--260-332 Others like a thinner, more transparent material http://www.speakerworks.com/speaker_grill_cloth_fabric_s/25.htm which is o.k. also. -
I might have misunderstood your question, if you were referring to the removal of the side panels to recover, I would think the procedure would be the same. The side panels on some of the big SDA's were attached with a "snap on" type connector, some were glued on the cabinet (which is not too tough to remove).
Yes, I was talking about removal procedure. Thanks for your reply.
The Parts Express cloth is inferior to some of the alternative out there. I have found the cloth used by Magnepan to work much better than the original in all respects.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Great to know. I have never replaced it entirely, just done restretch and repaire with spray adhesive or hot glue. How do you recommend attaching? I've seen staples but it doesn't look factory.
