Snatched up a pair of monitor 12s ? Opinions
Dropthebeat
Dropthebeat Posts: 154
edited January 2014 in Speakers
So I found a listing on Craigslist for a set of monitor 12s cabinets I'm decent shape 7 out of 10 the grills need to be replaced though and one blown tweeter of which I have two extras. I paid 100 ? I'm guessing I didn't overpay since it's not going to cost me anything to replace the tweeter
Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Sda 1c - my new favorite speakers
Rta 8,11tl,15tl
Monitor 10 and 12
Marty sub 18" still in the works
Klipsch sw12-2
Hobbies turn into addictions .
Post edited by Dropthebeat on
  • zane77
    zane77 Posts: 1,696
    edited January 2014
    Sounds like a very good price to me, enjoy.
    Two Channel
  • Dropthebeat
    edited January 2014
    Thanks , can't wait to clean them up and listen to them .
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Mystery
    Mystery Posts: 2,546
    edited January 2014
    I enjoyed them when I had them.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited January 2014
    Many will say that those have a little too much bass. So perhaps getting them out into the room would be a good place to start.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Dropthebeat
    edited January 2014
    I'll have them hooked up later tonight maybe , I'll report back afterwards ... Chipped a little piece of wood off the edge of the cabinet while carrying them through the door -_- .
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • transmaster
    transmaster Posts: 428
    edited January 2014
    I tried to purchase a pair of these new back in 1989 and I could not land a pair and ended up with a pair of 10B's which I am listening too right now. The Monitor 12's are fantastic!!!!!!!!!!!
    Those tweeters look like SL2500's that is the ferro-fluid cooled tweeter that Polk used in the final speakers of the original Monitor series
    Radio Station W7ITC
  • Indyaudio2
    Indyaudio2 Posts: 127
    edited January 2014
    Great buy for $100!
  • Dropthebeat
    edited January 2014
    Well the tweeter I put in replacement is actually a sl3000 it sounds much brighter than the 2500 . The speakers sounded great , but I can't help but to get a feeling something isn't right . They sound almost muffled compared to my rta11 or even my monitor 10s.
    The bass is definitely much louder , is there any way to tighten up the bass other than added insulation that I'll be buying tomorrow ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Loud & Clear
    edited January 2014
    The bass in those are overwhelming. I'm not sure I've seen anyone provide a proper fix as of yet. If anyone has I'm sure it would be greatly appreciated by those who own them.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited January 2014
    First off congratulations on the deal.Check cabinets for air leaks,you can use liquid nails on inside seams I believe.If gaskets on drivers are bad use armiseal-not sure of spelling,can be had at home depot. Use poly fill in cabinets not insulation.The old might just need to repositioned.Start there,I'm sure others will chime in.Hope that helps.
    Dan
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    Congrats your new speakers & hopefully youll get them squared away. Send a picture our way. That Monitor always remind me of the 1c's sorta. Enjoy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2014
    If you dynamat the drivers and passive it will tighten up the base a bit, however they can be a bit boomie by there nature.they do (like most polks I have owned) like a lot of power to proform at there best.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Phish56466
    Phish56466 Posts: 54
    edited January 2014
    Make sure you have a high current amp to drive them with. I'd consider doing the XO's if you're going to keep them(RDO's suggested as well as the usual Dynamat mods). For what they are, they're pretty clean and they will get LOUD!! I've also noticed with mine, that unless your grills are PERFECT they tend to rattle a bit. Just take them off and watch them work. I LOVE mine! BUT like most of us, I want the BIG ONES(just because)!
    Monitor 12's-RDO's and XO's done!
    Onkyo TX-SR705 AVR
    Adcom GFA-555 for power(being reborn, as I can afford it)
    Onkyo DX-C730 changer
    Onkyo CP-1057F table W/Grado cartridge
    CS300 center
    M4's for rears
    LG 47" LCD
    ROKU streaming gizmo
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited January 2014
    Just to carify, if it's the gaskets the product most used here is Armacell--AP/Armaflex insulation tape .I got a roll about $8 @ Home Depot. Some use Amaflex and Armacell interchangeably.
  • xjghost
    xjghost Posts: 1,115
    edited January 2014
    Those were my dream speakers back in the day when I got my 10's. I'd say around 88 or 89. Now that I'm divorced and have recently purchased a set of 3.1's I'm now on the lookout for a set of these.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • Dropthebeat
    edited January 2014
    I have a nad 2600a powering the two speakers , they sound very different compared to my other speakers but I like the sound they make , and that's all that matters I just hope I can get the bass to be a bit more punchier I feel it lingers as of now . I don't know if that's a good way to describe it. Thanks for all the input everyone , I'm going to do some of the things dan recommended hopefully that will help in improving their sound.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
    tonyb Posts: 33,065
    edited January 2014
    The bass has always been a tad slow, muddy on those old monitors even the R line and some of the RT's as well. Exception being the Monitor 5's and 7's in my book. Punchier bass happens when you hit the RTI line on up. Just my opinion based on past experiences.
  • Dropthebeat
    edited January 2014
    I like the speakers but they could never replaced rta11tl or 15.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Mystery
    edited January 2014
    nbrowser wrote: »
    Dangnabbit...those would pound like no tomorrow on my amp...me want ! :)
    Sorry, the bass lover in me is wanting out...lol
    When I sold them, I was in a townhouse so I had bass all the way to down -6 or something in the A/V receiver so it won't disturb neighbors too much.
    I auditioned them for the buyer and they all said, they have great bass.
    After they left with the speakers, I realized that I was auditioning them with the bass still all the way down at -6.
    Haha... yes they do have lots of bass.
  • Dropthebeat
    edited January 2014
    Just bought some poly fill and armaflex. Instead of dynamatting the drivers I was thinking about using a molding rubbery gasket material . Resembles the texture of gum . Does anyone see a possible issue with this or should it be fine ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Dropthebeat
    edited January 2014
    well I added some Polly fill, I added some rubbery gummy material to the drivers to help with resonance and used some of the armaflex to seal the drivers to the cabinet. The bass does sound a bit more controlled , the overall sound has improved but man do they produce a lot of bass and at all times lol I like them though, they're completely different from my other speakers. Thanks for all the input and advice everyone. Much appreciated.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Dropthebeat
    edited January 2014
    you can see in my pictures I have non matching tweeters. I couldn't find my other sl3000 :/
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Oldfatdogs
    edited January 2014
    In the words of a senior member when I first came here and told him I had miss matched tweeters in my 7Bs.
    ( Oh that not good ) As polity as he could. Tom I know your gonna snicker when you read this.
    Find a match asap,your ears will thank you.Glad everything else helped.
    Dan
  • Dropthebeat
    edited January 2014
    Well I bought them thinking I would sell them but I swapped over my rdo198 tweeters to see what they would sound like and I don't think I want to get rid of them, I love that they're a bass heavy ... What tweeter is recommended for these ? Stick with the originals or swap to the rdo198 ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • xjghost
    edited January 2014
    I want a set of these.
  • agfrost
    agfrost Posts: 2,460
    edited January 2014
    Well, the the RD-0-198 is the correct current-model replacement for the original SL2500 tweeter the M12 had, so feel free to leave 'em in there when you're listening to them. Sharing those tweets with the 11TLs or 15TLs?
    Jay
  • Dropthebeat
    edited January 2014
    my rta11tl came with the rdo198 and I purchased a pair for my rta15tl as well, but i plan on leaving them in there. I just cant find my other sl3000 tweeter out of my 15tls. So either I purchase another sl3000 or give in and do the TL mod.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
