Re-cabling and Larry's rings
Phish56466
Phish56466 Posts: 54
edited February 2014 in DIY, Mods & Tweaks
OK, don't flame me here. When I redid the XO's in my M12's, I left the factory wiring in place(to the drivers). Should I have redone this also? Would I notice any difference is the sound produced from doing said modification? Also wanting to get some of Larry's rings for these. For those who have them, could you tell me what I might be expecting by this? AND THERE GOES MY TAX REFUND!
Monitor 12's-RDO's and XO's done!
Onkyo TX-SR705 AVR
Adcom GFA-555 for power(being reborn, as I can afford it)
Onkyo DX-C730 changer
Onkyo CP-1057F table W/Grado cartridge
CS300 center
M4's for rears
LG 47" LCD
ROKU streaming gizmo
Post edited by Phish56466 on
    pitdogg2 Posts: 27,239
    edited January 2014
    Unless the wire was cut and patched I don't see much gain in new wire. you could drop high dollars on very good wire but as I said I do not think it would be for much gain. Larry's rings are a good investment. never to worry about a stripped screw hole ever again and tight to the front baffle.
    Toolfan66 Posts: 18,162
    edited January 2014
    Except I'm out of stock on the 6.5 rings, and tweeter brackets...
    Not sure when I will get around to running any more..
  • bobivxx
    bobivxx Posts: 14
    edited January 2014
    I'll buy a set for monitor 10's and a set for RTA12's when you do get around to making some more Larry. Let me know. Thanks!
  • jimsvm
    jimsvm Posts: 307
    edited January 2014
    I could use a set for my m10's as well. Pls and tks Larry.
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • Phish56466
    edited January 2014
    DANG IT LARRY! I'm sure you'll be a gentleman and let us all know when you make some more.
    Onkyo TX-SR705 AVR
    CS300 center
    M4's for rears
    LG 47" LCD
  • mikemokr
    mikemokr Posts: 150
    edited January 2014
    I too am not too proud to beg ... I'd be down for a set for CRS+ and maybe also Monitor 7 and/or old Model 5.
    Main HT (family room): Polk Monitor 7 (1987-original owner) (L/R) / CSi40 (C) / RTi38 (SL/SR) / SVS 20-39PC (sub), Outlaw 975 pre/pro / Outlaw 7075 amp, Oppo BDP-93 Blu-ray, LG 42LM5800 teevee
    2ch (family room): CRS+ (1987), Outlaw 1050 AVR, Denon DCM-420 CD
    Kitchen satellite 2ch: Polk M3II, Topping TP-20 Tripath amp fed from 975 rec line out
    Home office: Model 5 (1978-Danish Peerless), Lepai 2020A+ Tripath amp fed by laptop dock
    Awaiting assignment: PSW202 (NIB) to be wired inline in home office rig; Monitor 5JR (1988), Model 4 (1983-US Peerless)
  • iliveinyourhead
    iliveinyourhead Posts: 12
    edited January 2014
    Toolfan66 wrote: »
    here i am trying to work up 10 (legitimate) posts in order to PM you for info on rings only to find out i am years late .. :)
  • Hofy
    Hofy Posts: 169
    Add me to the list of ring wanters.
  • VCoak
    VCoak Posts: 200
    Larry I'm in for a set for the 1.2's. Was going to use mortite but you have them I will buy them. :)
    mco
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
    nooshinjohn Posts: 25,985
    Forget about the Moretite. Use Armacell instead. It seals better, easier to use, and compresses better than Moretite. As Larry tells it, the rings might not have existed in the first place if he used Armacell from the beginning. He made the rings to work with Moretite because screw holes were stripping out trying to compress the stuff.
  • Tronman
    Tronman Posts: 72
    I am in the process of upgrading my SDA-1C's and was wondering if Larry rings are still available? I am a long time reader and this is my first post. I am ordering the Sonicaps and Mills resistors and in the process of Dynamating the baskets and JB Welding the magnets of the woofers and Radiator. Any information on the Larry Rings if they are still being made would be great.
    I am also looking for some MW-6501 for some SDA-2 or SDA-2A (2) SL-2000 tweeters and (3) MW-6501 woofers. Two woofers are blown and have been unable to find replacements. Hope I am posting in the right place if not let me know.
    Thanks,
    Tim
    F1nut Posts: 51,953
    Tip, the PR's do not have magnets.
    Larry said the rings are out of stock. He said he'll make more at some point.
  • Tronman
    Tronman Posts: 72
    Sorry about that it was late at night and I was typing rather quickly - you are correct the PR have no magnets :-)
