speaker box mm2124's
Systems
im planning to build a bandpass box for two mm2124's and i want to follow the box plan here at polk but i dont understand the dimension that says "35-41/100" could someone please help?!?
Testing
Testing
Testing
Testing
Testing
that's to be exact... get to within 1/8", namely 35 and 3/8 inches.It's not good, very fundamentally simply not good. - geolemon
don't build a bandpass.
go sealed. its easiest and a hell of a lot better.- Slain -
Truly you know this from many other posts... POLK subs run better, cleaner, smoother, and LONGER in sealed boxed matched to them.
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
Yeah, let me throw my hat into the "pro sealed box" ring.
Theyre easier to build, can handle more power, are more forgiving of build errors and sound tighter.polkaudio sound quality competitor since 2005
as said, sealed is definately tighter, more reliable, and easier to build, as well as better for your speakers' longevity, but if you're set on the loud bandpass box, you picked the right momo sub to do it with...It's not good, very fundamentally simply not good. - geolemon
I am doing 2 2124's in a band pass today (3 chamber. polk's spec'd box). Going to break them in over 2 weeks with 150 watts each. I will let ya'll know what the eq., spl. turns out to be with 300w total.
2k Focus ZX3Pioneer Premier DEH-P860MP
2 Polk Audio MM2124's
More to come... -
be more careful than you think you need to be on breaking them in, just in caseIt's not good, very fundamentally simply not good. - geolemon
what he saidOriginally posted by neomagus00
OMG! 141.5 on an Audio Control unit. (300 total watts)
May not be W7 but that box plays notes that I only used to hear in systems that had 8 12's tuned LOW..
IE ZZTop, Heads in Mississippi. Erich Kunzel, Planet Krypton
Plays those UBER notes.
The tonal range for application is great too...
Nice and tight with the rumble for rock.
Kick butt on the Rap
Country romps
With the little power I am pushing to them they are hardly moving..
Cant wait till I put 800w to them....Pioneer Premier DEH-P860MP
More to come... -
sweet... glad it turned out the way you wanted... as long as you've broken them in, rock on!It's not good, very fundamentally simply not good. - geolemon
