Sectional really close to the powerport on my RTiA5, issue?
PolishDude
I am slowly setting up my new townhouse, the front wall will consist of two SVS PB1000s, RTiA5 towers and a CSiA6 center. My only concern is the chase section of the Sofa gets really close to the RTiA5, I will have 24" between the wall and chase portion of my sofa. The chase is only 15" tall, so it doesn't cover the drivers. I can have the speaker really close to the wall and have 10 inches between the port and the sofa, or in the middle, etc. The speakers will be over 2 feet away from the corner so that is not a concern.
Post edited by PolishDude on
Not too worried about the bass with the dual PB1000s, if I moved the speakers a foot off the wall, the left side one would be against the couch.
I can always sell the RTiA5 and buy bookshelves and stands if that is a better option?
I think you'll be fine. Only your EARS can tell you for sure.
