Test points for BIAS and DC on Adcom GFA-555 II.
Mystery
Mystery Posts: 2,546
edited January 2014 in Electronics
I got an Adcom GFA-555 II just last night and it's not working.
I can't find test points TP201, TP301, TP251 and TP351 in the service manual and they are not labeled on the board. :mad:
Are the two pins highlighted in red the test points?
If yes, are the two points together for one channel?
Thanks.
Post edited by Mystery on
    billbillw Posts: 7,748
    edited January 2014
    Um, if its not working, Bias and DC offset won't matter.
    Regardless, DC offset is measured at the speaker terminals. I don't think there is an adjustment on the Adcoms.
    Bias is usually measured on test points near the output transistors or on the legs of the transistors themselves. I don't think those are the bias test points, but those are the variable resistors you need to adjust. Look on the boards that connect to the metal can output transistors.
    Be VERY careful when dealing with these test points. A slip of the probe can short out and fry whole output stage in a heartbeat!
    EDIT: Looking at some other photos of that amp, I think your test points are the long (single, unconnected) metal rods sticking off of each of the output boards. You will test between the two boards for each channel. One side is the NPN the other side is the PNP. Use alligator clips if you can to avoid slips.
  • Mystery
    edited January 2014
    Thanks Bill.
    Here is a picture of the amp.
    I think I need to look at the boards that are pointed with the arrow.
    edited January 2014
    Yes, each of those boards should have a single metal pin sticking out, no wires attached. Test voltage across the pins of the right channel boards and left channel boards. If you get a good look in there, they should be labeled as J301, etc. Just be careful, don't touch anything else. If you don't have alligator clips, I might think twice.
  • Mystery
    edited January 2014
    I checked all the fuses' values and it was a mix.
    One was 5A which was blown 5A, two were correct 7A (AGC 7A-250V/312) and one was 6A.
    I replaced the two 5A and 6A with 7A and now it is working fine.
    I found the test points. They are small metal bars on the vertical boards.
    However, setting bias is so weird.
    When I adjust the resistor, it changes value but automatically comes back to around zero soon after when no input is connected.
    Then I connected input signal and played a track and bias went up and down depending upon the music, around 14 to 18mV.
    So basically, can't adjust bias.
    Also checked DC voltage and it was close to 0 fluctuating sometimes to .001 so I guess it's good.
    I read this amp doesn't have speaker protection so that's something to read next.
    Here are the test points for reference highlighted in red circle.
    However, they are not numbered TP201, TP301, TP251 and TP351 as mentioned in the service manual.
    The numbers were J### something.
    Thanks for comments.
    edited January 2014
    Bias should only be measured with no signal, after the amp is warmed up to full operating temps. Don't worry about what its doing when a signal is playing.
  • Mystery
    edited January 2014
    Okay thanks.
    How about protecting speakers from this amp?
    It doesn't have speaker protection circuit.
    Can it be added inside or something external like in-line fuse work?
    edited January 2014
    Mystery wrote: »
    Okay thanks.
    Not an easy addition. There are plenty of DIY sites that talk about it, but it may be beyond what you want to do. It is definitely a drawback of that amp.
  • Mystery
    edited January 2014
    I see. I have speaker selector with amp protection but need something with speaker protection as I think the speaker selector only has a resistor and no protection on DC voltage. :wink:
    I'm still bothered by the bias pots.
    Turning R119 and R169 doesn't change mV readings and even if it changes, it resets back to 0.
    I'll try again and see how that goes. :confused:
  • Phish56466
    Phish56466 Posts: 54
    edited January 2014
    http://akdatabase.org/AKview/albums/userpics/10004/Adcom%20GFA-555II%20Service.pdf
    https://groups.google.com/forum/#!topic/rec.audio.misc/sRdukGzkSfk
    First addy is the service manual. The second is a REALLY good read. I've been changing out passives in my 555 and have noticed SOME difference in sound quality(for what I've got). MOST of it has been done for reliability reasons though. Mine NEVER gets powered down unless I'm modding it. I'd suggest you do the same, unless you're worried about the electric meter.
    Monitor 12's-RDO's and XO's done!
    Onkyo TX-SR705 AVR
    Adcom GFA-555 for power(being reborn, as I can afford it)
    Onkyo DX-C730 changer
    Onkyo CP-1057F table W/Grado cartridge
    CS300 center
    M4's for rears
    LG 47" LCD
    ROKU streaming gizmo
    edited January 2014
    Mystery wrote: »
    Are you sure you are measuring correctly? Set the meter to be in correct DC mV range? Points connected to the R-ch NPN and R-ch PNP test points? You should easily see the bias voltage.
  • Mystery
    edited January 2014
    So far it's running good...
    I tested the amp with some test speakers for around 4 hours continuous at moderately high levels and it felt very slightly warm on both sides.
    It's not even hot at all.
    So I plugged in the Boston A400's and listened all day yesterday.
    I have not tested the Bias but it's more or less exactly in the middle as it was before I adjusted it.
    I'm guessing it may be off by few mV's in the two channels but that shouldn't hurt right?
    Here is the setup in my living room:
    Philips 312 Turntable.
    Yamaha CD Player (I have a Nakamichi CD player somewhere in the basement that'll replace it soon).
    Harman Kardon Signature Series AP2500 Pre-amplifier.
    Adcom GFA-555 II Amplifier.
    Marantz 3000 Cassette Player.
    Boston Acoustics A400 Speakers.
    Definitive Technology PF15TL+ subwoofer.
  • Glen B
    Glen B Posts: 269
    edited January 2014
    Mystery wrote: »
    Okay thanks.
    DC protection circuitry/output relays can be added in an amp if there is room, but that is a job for an experienced DIYer. You can mount the protection circuitry it in an external box connected between the amp and speakers. Here is a protection kit that has a built-in power supply: http://www.parts-express.com/velleman-k4700u-2-channel-loudspeaker-protection-kit--320-264?utm_source=google&utm_medium=cpc&utm_campaign=pla. You just need to connect it to the AC mains, which can be accomplished somewhere after the amplifier power switch.
    Here is my Phase Linear 400 Series 2 in which I installed DC protection. I mounted the two single-channel boards back-to-back on the side wall of the chassis (on the far right). I obtained operating power for the circuit directly off the main power supply, through a voltage divider network (tiny board between the big caps and main board). I am preparing to install protection circuitry in an Acurus A250 I bought recently.
    PL400-2_09_zps5a473ad2.jpg~original
    PL400-2_11.jpg~original
    PL400-2_10.jpg~original
  • Mystery
    edited January 2014
    It's running so far so good and I don't think I'm that skilled to add DC protection myself.
    I'll use it as it is for now and think about replacing capacitors later.
    thanks
  • APAPAS
    APAPAS Posts: 1
    Just purchased 2x Adcom GFA 555se. Listening and owned a lot of amplifiers I always thought my Adcom GFA 545 mkII sounded more precise,detailed and with much tighter and better low end than my i.e Cambridge Audio CXA80 (2016) design.
    With this criteria i purchased two 2x Adcom GFA 555se, intending to use them in vertical passive bi-amping configuration for my B&W 805s. Mainly I am using The Audio Cambridge CXN as a digital source for TIDAL, Spotify, and FLACK from NAS drives. using one of the new Adcoms on stero mode after few days of burning inn, i notice great improvement in all areas apart than I would have to say the bass was a bit bloated compared to the 545 MKII,
    Also i noticed the heat-sinks temperatures had a really big difference working under the same conditions. Left Chanel with right Chanel unit 1 ( L slightly warm, R Almost cold). Unit 2 ( L warm to Hot , R Almost warm).
    1. Can anybody explain why, and if Bias , dc offset has something to do with it.
    2. Any ideas why the bass sounds bit bloated and if any cure.
