posting pix by myself
leftwinger57
leftwinger57 Posts: 2,917
edited January 2014 in Vintage Speakers
Here goes nothing, I'm back home w/ no help from anyone and I'm going to try once more.You might have seen these before but I have to do this on my own.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited January 2014
    Holy crap those are big pictures. I'm glad you weren't in the pics since your shorts were hanging on the chair. Lol.
    I assume you are using a windows based system. Open the pics on your computer one at the time. right click on the computer and select open with some sort of picture manager. the windows version is called Microsoft picture manager I believe. Once open, find edit and select re-size. Re-size the picture and click save. it's the easiest way i know of.
  • leftwinger57
    edited January 2014
    Yes they are really big.I'm missing a step or 2 and I'm lost again. it's Windows XP and that's all I know about that. When posting before I was able to preview pics and now that's not possible and this kind of stuff gets out which is totally unexceptable.Also prior in the drag and drop area pictures would show up now I get squares w/an insignia in them and no picture. I haven't the slightest idea what happened but if you go to "trying to load pix" at the last post is the end result of my nephew trying this out.He got the thing to work. His pc is different than mine so when I got home everything was different like going into attributes to change sizes then his had a % location and mine doesn't or I have no idea where it inhabits.The shorts were not part of the shot, it was supposed to be my ADC303ax and either my old Infinitys or Time Frame 350s just for test purposes.Great test..
  • leftwinger57
    edited January 2014
    trying agin w/ more directions
  • leftwinger57
    edited January 2014
    Not exactly the whole shot I wanted. Mr Bubbles your idea brought me to the same place in paint then I size the pix but evidently sizing is the issue,you think. Cablevision told me to make the sizes width17 and lenght 12.75 and then there was a % on the other computer but I still don't see that. Sh$t.If I was captured as a war prisoner and they said will let you go if you can post up some nice audio **** for us, I'd have to say shoot me now and get it over with....wa wa wa
  • halo71
    halo71 Posts: 4,637
    edited January 2014
    Would be a lot easier if you signed up at a photo hosting site like photobucket.com. Upload the pics there and then copy the code and post directly to a website.
    --Gary--
  • Mr. Bubbles
    edited January 2014
    in XP locate the thumbnails of the pictures you want one at the time. Right click on it. place cursor over "open With". select windows picture manager. When picture opens look near center top of page on tool bar. You should see "edit Picture" click there. Then look to the right side of page where functions are listed in side bar. locate "resize". input your desired dimensions and save. You now should have a smaller picture saved to your computer. You can then upload that new one.
  • TennMan
    TennMan Posts: 1,266
    edited January 2014
    I don't understand why we should have to re-size the photos when the vBulletin forum software should be doing it automatically. Correcting the software problem would be much easier than us having to re-size every photo that is uploaded. Is there a reason the problem with the software hasn't been addressed?
