Connecting processor to receiver
NeilGabriel
NeilGabriel Posts: 1,487
Is there anything more complicated to hook a 7.1 channel processor to my Rotel receiver than running the processor's 7.1 outputs
to the receiver's 7.1 inputs? I need the multiple hdmi inputs the receiver lacks. Then all audio sources plug into the processor?
How is volume controlled when you use the receiver for power only? Where is volume on the receiver set?
thanks
Post edited by NeilGabriel on
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2014
    The processor should be at full volume/signal all the time, and you use the receiver's volume control. Generally a receiver's volume is set on that big dial on the front, or the buttons labeled "volume up/volume down" on the remote.
    Main Surround -
  • NeilGabriel
    edited January 2014
    nguyendot wrote: »
    Thanks. The first time I bought a power amp, I was very confused that there was no volume control. Then I learned volume was controlled through the pre/pro. I have had many receivers and separates but never hybridized them.
    tonyb Posts: 33,068
    edited January 2014
    You would get better sound if you sold the receiver and bought an amp. Right now, the amp section in the receiver is all your using it for.
