It's Sofa King Cold!!!
ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
The guy i saw on the Motorcycle today would say everyone here is a wimp. call me whatever as i turn the heater knob up.
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
2 in of snow down here is cause for alarm. Schools will close, people will make a mad dash to the store for bread and milk like they were going to be home bound for days. I just kick it into 4 wheel drive and head to the craft beer store. LOL
Quincy is finally up to 12F with a wind chill that makes it feel like 0F I thought about going out, now I'm staying in with my heat up to 76 & my space heater on high.
Stay warm Polkies.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
nooshinjohn wrote: »It was a frigid 82 degrees here in Woodland Hills today.
It must be nice!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Where did this one come from?
It's so cold it can freeze the balls off a brass monkey!
In the heyday of sailing ships, all war ships and many freighters
carried iron cannons. Those cannon fired round iron cannon balls. It was
necessary to keep a good supply near the cannon. But how to prevent them
from rolling about the deck?
The best storage method devised was a square based pyramid with one
ball on top, resting on four resting on nine which rested on sixteen.
Thus, a supply of thirty cannon balls could be stacked in a small area
right next to the cannon.
There was only one problem -- how to prevent the bottom layer from
sliding/rolling from under the others. The solution was a metal plate
called a "Monkey" with sixteen round indentations. But, if this plate
was made of iron, the iron balls would quickly rust to it. The solution
to the rusting problem was to make "Brass Monkeys."
Few landlubbers realize that brass contracts much more and much
faster than iron when chilled. Consequently, when the temperature dropped
too far, the brass indentations would shrink so much that the iron cannon
balls would come right off the monkey. Thus, it was quite literally,
"Cold enough to freeze the balls off a brass monkey!"
(And all this time, you thought that was a dirty expression, didn't you?)
I know I know I am a veritable Costco of useless trivia.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
this:
This isn't bad if you're old enough to remember 1977.
It must be nice!
Not to rub it in, but yes... yes it is!
http://www.weather.com/weather/tenday/Woodland+Hills+CA+91367:4:US
It DOES get cold at night though.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
9 degrees in South Carolina is just wrong.
I moved down here to get away from the cold.
I see St Pete or Big Pine Key in my future.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
Tubes have a certain warmth! Get more tubes!My New Year's resolution is 3840 × 2160
