Sherbourn 5/5210a DC area $500
nwohlford
nwohlford Posts: 700
edited January 2014 in For Sale (FS) Classifieds
The amp is good shape with a small nick or two. The button to turn off the LEDs is stuck and I have not been able to free it. (LEDs are stuck on.) The only thing included with the amp are two basic power cords. I can send pictures to anyone who is interested. It is available local only (22204 zip in Arlington, VA) as the amplifier is 80+ lbs and I don't have the packing materials. I am only selling because I am using it in a two-channel system that I had thought about changing into a five-channel system. Since the change never happened, it would make sense to switch to a smaller amp.
The product brochure is available here: www.avation.biz/products/Sherbourn/72100amp.pdf.
Models 7/2100A and 5/5210A
• 56 discrete output devices and outputs 200/300 watts 8/4 ohms per channel with all channels driven
• Seven mono blocks, each of which has over 20,000 micro farad capacitance; Model 5/5210A has only five mono blocks
• Large heat-sinks for maintaining a cool, fan-free operation
• Seven 400VA toroidal transformers to yield an equal power to all channels
• 4 ohm output of 2.1 Kw requires up to 28 amps; two power cords negate the need for a
30 amp circuit and instead each cord can go into a separate 15 amp outlet
• Can be bridged into 8 ohms for an awesome “front stage” of 400 watts per channel
• Seven sets of XLR balanced outputs, seven sets of RCA unbalanced inputs, seven sets of gold-plated binding posts,
a low-volt trigger for remote integration and a 3-way music sensing circuit switch
• Patent Pending LDS circuitry that allows for testing of all connections for short circuits
Post edited by nwohlford on
    EndersShadow Posts: 17,704
    edited January 2014
    This thing is a HOSS and would be a VERY nice upgrade for anyone looking for a amp for their RTi or LSi setup.
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2014
    Wow, not sure how you could possibly do better for the price...
    GLWTS!
  • B Run
    B Run Posts: 1,888
    edited January 2014
    That's a sweet amp at a great price, glwts!
  • xftman
    xftman Posts: 153
    edited January 2014
    How is this compare to Emo XPA-5?
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2014
    Superior.
  • nwohlford
    edited January 2014
    If there is anybody who is local and interested, let me know. We can probably work something out. I have had a few bites on CL, but I would rather not deal with them if I don't have to.
  • nwohlford
    edited January 2014
    ZLTFUL wrote: »
    If you end up considering shipping, I would be your huckleberry.
    The heaviest amp that I have had to package and send was just above 50 lbs. 85 lbs seems a lot heavier, and I would be worried about the possibility that it would get damaged.
  • xftman
    xftman Posts: 153
    edited January 2014
    I am local and interested. I am also interested in falconcry72 LsiM707, 706C to match my newly acquired 703 too. But I don't how's this amp compare to Emo XPA-5 which I currently owned. How well this one work with LsiM?
    MAIN:
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • nwohlford
    edited January 2014
    xftman wrote: »
    How local? If you are nearby, I am fine with you trying it out. I currently have a tentative appointment with a person off CL, but if you are really interested in it, we could try to work something out.
  • xftman
    xftman Posts: 153
    edited January 2014
    North of Baltimore.
    MAIN:
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • shawn474
    shawn474 Posts: 3,052
    edited January 2014
    Pm sent
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • nwohlford
    edited January 2014
    Please mark as sold.
