Squeezebox Touch Power Supply
squeeb
squeeb Posts: 426
edited January 2014 in Electronics
Looking at a couple of different SBT power supply upgrades. Thoughts? Experience with either? Other options in similar price range ($300+/-)?
Welborne Labs - http://welbornelabs.com/cat/squeezeboxpowersupplyupgrades.htm
Channel Island - http://www.ciaudio.com/products/VDC5MKII
Thanks.
7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
Post edited by squeeb on
  • dkg999
    dkg999 Posts: 5,647
    edited January 2014
    There have been numerous business issues in the past with Wellborne Labs. I had to reverse some duplicate credit card charges from them on the last SBT power supply I ordered from them. I would do some research and approach with caution. That said, I am completely happy with both my Wellborne Labs power supplies.
    DKG999
  • Emlyn
    Emlyn Posts: 4,790
    edited January 2014
    It took me about 3 months to get one of the pre-assembled Welbourne power supplies. Having said that, when it did arrive it was flawless. I ordered one in red, so they had to special order the case because they had none in stock.
    Customer service was there, but they are slow and offer no apologies for delays. But, at least they are consistently slow. I wouldn't order another one, because the other three SBT's I use around the house aren't used for any kind of critical listening.
    SCompRacer Posts: 9,121
    edited January 2014
    I had ordered a PS kit from them in 2010. No charge card issues, but slow, incomplete order with note saying the rest will follow and it did.
    EndersShadow Posts: 17,715
    edited January 2014
    There is a legit company on eBay that sells them for like 150. I will find and post the link later when I am on my pc
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2014
    Is it TeraDak
    I was looking at that one
    Garage | Polk Monitor 5B's
