It's Sofa King Cold!!!
  • Jhayman
    Jhayman Posts: 1,548
    edited January 2014
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    The guy i saw on the Motorcycle today would say everyone here is a wimp. call me whatever as i turn the heater knob up. :smile:
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • mytime
    mytime Posts: 87
    edited January 2014
    2 in of snow down here is cause for alarm. Schools will close, people will make a mad dash to the store for bread and milk like they were going to be home bound for days. I just kick it into 4 wheel drive and head to the craft beer store. LOL
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2014
    Quincy is finally up to 12F with a wind chill that makes it feel like 0F I thought about going out, now I'm staying in with my heat up to 76 & my space heater on high.
    Stay warm Polkies.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2014
    It was a frigid 82 degrees here in Woodland Hills today. :lol:
    It must be nice!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2014
    Where did this one come from?
    It's so cold it can freeze the balls off a brass monkey!
    In the heyday of sailing ships, all war ships and many freighters
    carried iron cannons. Those cannon fired round iron cannon balls. It was
    necessary to keep a good supply near the cannon. But how to prevent them
    from rolling about the deck?
    The best storage method devised was a square based pyramid with one
    ball on top, resting on four resting on nine which rested on sixteen.
    Thus, a supply of thirty cannon balls could be stacked in a small area
    right next to the cannon.
    There was only one problem -- how to prevent the bottom layer from
    sliding/rolling from under the others. The solution was a metal plate
    called a "Monkey" with sixteen round indentations. But, if this plate
    was made of iron, the iron balls would quickly rust to it. The solution
    to the rusting problem was to make "Brass Monkeys."
    Few landlubbers realize that brass contracts much more and much
    faster than iron when chilled. Consequently, when the temperature dropped
    too far, the brass indentations would shrink so much that the iron cannon
    balls would come right off the monkey. Thus, it was quite literally,
    "Cold enough to freeze the balls off a brass monkey!"
    (And all this time, you thought that was a dirty expression, didn't you?)
    I know I know I am a veritable Costco of useless trivia.
    Garage | Polk Monitor 5B's
  • Mikey081057
    edited January 2014
    this:
  • chumlie
    chumlie Posts: 8,658
    edited January 2014
    This isn't bad if you're old enough to remember 1977.
  • Mikey081057
    edited January 2014
    chumlie wrote: »
    Unfortunately i am
    nooshinjohn Posts: 25,930
    edited January 2014
    danz1906 wrote: »
    It must be nice!
    Not to rub it in, but yes... yes it is!:lol:
    http://www.weather.com/weather/tenday/Woodland+Hills+CA+91367:4:US
    It DOES get cold at night though.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited January 2014
    9 degrees in South Carolina is just wrong.
    I moved down here to get away from the cold.
    I see St Pete or Big Pine Key in my future.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • Mikey081057
    edited January 2014
    Tubes have a certain warmth! Get more tubes!
