Center Speaker ? Would this work?
boston1450
boston1450 Posts: 7,758
edited January 2014 in Speakers
If i were to use 2 center speakers (CSi3) side by side..
Using the front center channel & rear center channel on a Yamaha RXV1 @ 110wpc (which has the rear center channel)..
I really enjoy my center channel speaker & was wondering if i was to use 2 side by side in the front- would this work ? Would it make it in my face bliss ? Or just a overkill ? I am thinking of upgrading speakers & receiver & really like the CSi3 on movies.. Thanks in advance. Randy
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
  • Mystery
    Mystery Posts: 2,546
    edited December 2013
    I've used two speakers as center without any issue.
    Not sure if front and rear center channels are exactly same.
    I'd rather use both on the same front center channel connection.
    Just give attention on wiring as parallel drops impedance while series adds.
  • rpf65
    rpf65 Posts: 2,127
    I'm fairly sure the rear center speaker channel will receive signals that rear surrounds would receive.
  • Mystery
    rpf65 wrote: »
    If that's the case, it's not a good idea to use both front and rear center as fronts.
  • boston1450
    The signal may be different. Got it. Need to research this idea
    Randy-Maine
    by David WMG
    tonyb Posts: 33,065
    edited January 2014
    Just get a bigger center channel speaker.
    edited January 2014
    There are a couple of people here who use a dual center where the centers are ABOVE and BELOW each other.
    One above your TV, one just below it, or some such configuration; I've never tried this.
    cnh
