Single cable Amp out put to sub with stero input.
KJC
I have this older Amp, a JVC RX-5030V, and i just bought a Polk speaker package, Polk RM-705. Now, a detail that i missed when matching up the specs on these two products is the fact that the amp has a single 'Sub Out' and the Sub has a right and left input RCA input, is this something that i need to be worried about?
Advice Please.
Advice Please.
Post edited by KJC on
http://www.monoprice.com/Product?c_id=102&cp_id=10218&cs_id=1021803&p_id=663&seq=1&format=2
It's cheap and will get you up and running. You will still need a RCA cable though.AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
Sub-Velodyne SPL-1000R -
I think with most subs it's fine to just plug the subwoofer cable into the left input. Set the receiver's subwoofer level to -4, say, and adjust the subwoofer's amp to your liking. Now maybe your particular subwoofer is different, but most of the time you don't need to connect to both left and right inputs.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
