Looking for Speaker Cable Suggestions
mufsoman
mufsoman Posts: 636
Looking for suggestions for upgraded speaker cables. I'm currently using Monoprice 12 ga stranded wire (L/C/R are bi-wired) with Nokimichi nanners and know i can do better with sound quality with better cables. Not looking to start a cable debate, just looking for recommendations, so please keep it to that. I want to keep the front sound stage bi-wired and use nanners or spades. Lengths would be 8'/4'/8'. You can see the equipment I have in my signature below. Don't want to add to brightness of Rti's, but definitely want bass friendly cables. Need to keep the total spend under $500.
Both Doug and Tonyb have already provided input which has been greatly appreciated. Just looking for more input before plunking down some cash. Dougs cables are on my maybe list along with Blue Jean Cables Canare wire cables, Anti-Cables and Morrow Audio (to match my IC's).
Help with your suggestions!!!! Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
  • bobsauto49
    bobsauto49 Posts: 973
    edited December 2013
    Look into Analysis Plus offerings! Great cable for the money! Highly reviewed, and recommended!
    "Everything I ever did in my life worthwhile I caught hell for"
    tonyb Posts: 33,065
    Canare is a great sounding cable for not a lot of coin if your budget minded. For the RTI's I might add a warmer sounding cable Like the Kimber 8tc. All depends on budget really. Grover is another that's getting some great reviews. Since you have Morrow IC's, I might give their speaker cables a whirl and see how the whole set sounds.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Wireworld eclipse 6 for $400 used, I have them and I am going round the block to the big boys and find that for the mney they are awfully hard to beat.
  • Thorton
    Thorton Posts: 1,324
    Signal Cable. Polk Club discount offered.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • PolkieMan
    PolkieMan Posts: 2,446
    Please post the differences that you discover with the replacement wire.
    mufsoman wrote: »
