First tube amp?
halo71
I have never had an audio tube amp before. I have had many tubed guitar amps over the years. But audio tubes....is new to me. Can someone tell me about a 6ca4 single end magnavox tube amp? Is this a pretty decent amp?
Pic of it here....
http://www.flickr.com/photos/71542092@N00/11472733005/
Inside looks sorta rough though. Sloppy solder joints!
http://www.flickr.com/photos/71542092@N00/11472828216/in/photostream/
Pic of it here....
--Gary--
Post edited by halo71 on
That amp's been profoundly modified from its Maggotbox origins - most likely started life as single-ended EL84 stereo amp in a phono or low(er) end console.
They look like this "as found" :-) (borrowed photo, not mine!)
Umm... a 6CA4 is a rectifier :-) the outputs are probably (still) EL84 (6BQ5) although those look like modern Russian or Chinese ones rather than the original US or European tubes that Magnavox'd put in there.
Solder work looks OK to me at a quick glance; good quality parts.
It's cute that someone put a stepped attenuator volume control on it.
If it's a good circuit design and well implemented, it'll probably slaughter anything storebought under a kilobuck or so... with suitable loudspeakers. Should be about 4 watts per channel if in its normal (pentode) mode; if it's been modified to run the outputs in triode mode, you're looking at 1 to 2 watts per channel. Fine with, for example, Klipschorns, Altec Voice of the Theatres, Altec Duplexes, or Lowthers. You'll want loudspeakers with sensitivities at least in the high nineties for sensitivity (@ 1 meter driven with 1 wattt) to do it justice - or use it as a HF or MR/HF amplifier in a bi- or tri-amp system.
Da applications **** on the EL84/6BQ5 http://www.retrovox.com.au/STC6BQ5.pdf
EDIT: You can see a more typical re-implementation of a very similar amp chassis (if not identical) at:
http://www.polkaudio.com/forums/showthread.php?113687-Have-You-Listened-to-a-Low-Power-Amplifier&p=1512993&viewfull=1#post1512993 -
Skip which one would you suggest? Mark thanks for the info! I believe I have some speakers that would work with this amp. The main reason I am looking at this one is because of its price. Pretty damn cheap. If anyone has something laying around in the $150 range let me know please. Or a cheap way for me to get into tubes.
--Gary--
Tell us what speakers you're thinkin' about ;-)
A pair of Cannon TLS-1232TLS. I do not know the specs on them but they are very efficient. These in the pic are not mine, but they look just like them. I restored mine last year sometime. They are from 1978 or so. They were built by ESS.--Gary--
Too bad you don't live a little further north ;-)
Those little Maggotbox amp punch way beyond their weight - they were stoopit simple and made to conserve costs... but they had some sort of synergy goin' on that makes them genuinely hifi amplifiers; easy to rehab and (usually) cheap to obtain.
I have only one any more (a push-pull stereo EL84) but it was a freebie (dump find) and I have no complaints :-) -
Seems the seller decided he wants more now for the amp than what he had listed it for. So that one is out! I told him he should have listed it on eBay if he was gonna take bids on the damn thing!--Gary--
Because I am The Pumpkinking
I will have to wait. My budget was around $175. Was wanting to get into tubes on the cheap. And I mean CHEAP! lol--Gary--
Best way to start into tubes in my opinion is to start with the preamp, lot less hassle and you can experiment with tube rolling for much cheaper than rolling power tubes.2Ch Tube Audio Convert -
Exactly....or a tube buffer. Rolling tubes in an amp will cost a buck fifty easily just for the tubes let alone the iron. Tubes is not something to get into on the cheap, especially that cheap. Just sayin'....HT SYSTEM-
lsi 9's -
Well I was thinking a tubed preamp. I've seen some in that price range but don't know enough about them to know what to look for.--Gary--
Doesn't get any cheaper than this. Hows 40 bucks ?
http://chicago.craigslist.org/chc/ele/4256598406.htmlHT SYSTEM-
