How do you take apart an LSiM speaker?
I want to take a look inside, what is the procedure to get them apart?
Vinyl, the final frontier...
Post edited by madmax on
Circular saw?
ummm if it were me I'd use a screw driver......THEN work up to a sawsall
In all seriousness, the Polk website if I recall has some cut away pics in the LSiM product pages, save yourself the work and possibly damaging a great speaker.
I think this is the best advice... they are build to withstand the prying eyes of mere mortals.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
a jump to the left, then a step to the right, put your hands on your hips, and bend your knees in time, and then a pelvic thrust,
pretty sure thats the method the pros use, FYI: it really drives you insane2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Recently had to do this as I bought a 703 that came with a defective tweeter. The figure 8 rubber piece comes off first - I used a flathead screwdriver to carefully pry back a section and then pulled the whole thing off with my fingers. After that it's just a matter of unscrewing things until you get what you you're after.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
The best way to open them up, is with a good amp..
Now this would be the BEST answer...EVER!!!! -
Shotgun.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
seabeerob213 wrote: »a jump to the left, then a step to the right, put your hands on your hips, and bend your knees in time, and then a pelvic thrust,
Great Scott!
Good advice there...So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Loud & Clear wrote: »Recently had to do this as I bought a 703 that came with a defective tweeter. The figure 8 rubber piece comes off first - I used a flathead screwdriver to carefully pry back a section and then pulled the whole thing off with my fingers. After that it's just a matter of unscrewing things until you get what you you're after.
Thanks for the info! Is there any particular place where prying would be the safest?Vinyl, the final frontier...
Ship the LSiM of your choice (the one you want to have opened) to yourself using one of our wonderful mail carriers (they all will be able to accomplish this act)....
Inspect upon receipt...
It couldn't get easier than that! -
LSiM-703
Plastic spoon/fork -
Midbass/Pry from the outside inwards, middle of gasket, will come off easy
Tweeter/Midrange - I pried very carefully under the midrange surround, the rubber is adhered on. There is a white piece behind it that has approx. 8 hidden screws that hold everything on.
There is a crossover at the top and bottom.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Now that is impressive, but not out of this world - my LSiM had some inside pieces that had come loose during shipment- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If these are like other Polk speakers from recent years, they are designed to be assembled quick and easy. So that would me that they should be easy to dissasemble. The "beauty rings" that the LSiM are become more and more common. Most are just press/lock fit and are easy to remove. If you don't have on, get yourseld a plastic/nylon pry bar like these used in this kit:
Can find them cheap on eBay, Amazon, or a local store.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
The LSiM is not what I would call an easy speaker to mess with... the top beauty ring is adhered on but it is a strong rubber- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Best not to blow a tweeter on these if you can avoid it. Mine came with a damaged tweeter. Unpleasant to replace. Wiring is very short and this makes for very difficult working conditions. I had to use a phillips head drill bit to screw the tweeter into its bracket with my fingers. Not ideal.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
Throw it against the wall.Circular saw?ummm if it were me I'd use a screw driver......THEN work up to a sawsallShotgun.
Is it just me or is everyone around here especially ornery lately? Loving these responses!Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
Maybe they were trying to make them VR3 proof2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
