2 ch amp curiousity
snake1
snake1 Posts: 567
edited December 2013 in Electronics
Well, Geoff4rcf and I have been having a conversation and figure someone on here would know. What is the possibility of hooking up 4 speakers to a 2 channel amp? Basically bi-wiring in reverse. Split the wires coming out of the amp to power 4 speakers instead of 2. Thoughts???
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
    billbillw Posts: 7,538
    That's old school. It was sorta popular in the 60s/70s. But back then, most affordable speakers really couldn't handle much power. So people set up matching pairs in a stacked array. They could get 3db louder with the stack than with a single pair. Some of the folks over at AK still do this with arrays of Large Advents or other similar speakers. It can work OK if both sets of speakers are 8 ohms nominal, but I would not try it with 4-ohm speakers.
    Overall, it ruins the imaging. Stick with one pair, you'll be happier.
  • snake1
    snake1 Posts: 567
    What about a multichannel amp running normal wiring but the AVR setup with Audyssey DSX configured for wides and using towers?? Would it work with 2 towers for L and 2 for right running stereo?? Would the Audyssey config 'fix' imaging for 4 speaker front stereo sound??
    ps hope this explanation makes sense haha!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • polkfarmboy
    polkfarmboy Posts: 5,703
    4 speaker and front stereo sound wrong to me but ADSY should tune the two pair as one and provide some kind of 'fix'
  • snake1
    snake1 Posts: 567
    that is kinda what I'm thinking
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • polkfarmboy
    Hope your not planning on running two set or mixing with those rti12's
    mhardy6647 Posts: 35,013
    Mark Levinson rather famously stacked Quad ESL-57s; there are numerous folks who'll assert that these Mark Levinson "HQD" loudspeaker systems were the finest reproducers. Ever.
    http://soundartiwakura.jp/bbs/data/cheditor/0707/soundartiwakurahqd72.jpg
  • 4xoddic
    4xoddic Posts: 372
    Those are some big looms. Now I understand use of the terms weft, woof, & filler by audiophiles.
  • snake1
    snake1 Posts: 567
    Thinking about running another set of 12s as wides for surround but also wondering about 4 of them in stereo using audyssey dsx.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • 4xoddic
    4xoddic Posts: 372
    Comb Filtering, Acoustical Interference, & Power Response in Loudspeakers
    http://www.audioholics.com/loudspeaker-design/comb-filtering
    My inadequate understanding of audyssey dsx & Pioneer MCACC would lead me to believe each speaker is adjusted individually; and the programs have little, or NO, capability to adjust for the effects of comb filtering when all speakers are emanating waves. It's the interaction of these waves as they pass your ears that leads to some frequencies canceling & others adding up to greater dBs.
    I used to enjoy teaching waves in Gen. Science. Take a really long rope & put a knot in every meter. Force the students outside & line up on the sidewalk to get an understanding of the wavelengths of their fav FM stations. Unfortunately, USDs frown on buying all the science toys useful to study wavelengths, refraction, diffraction, comb filtering. Anybody else have a pair of diffraction grating sunglasses?
    http://www.rainbowsymphonystore.com/diffraction-grating.html
  • Face
    Face Posts: 14,340
    I like Audyssey for setting distances and levels, but it's best to fine tune yourself...especially in the bass region. A tool such as the Omnimic with the multi-channel DVD are perfect for this.
  • aboroth00
    aboroth00 Posts: 1,106
    Running speakers in parallel from a 2ch amp will half the resistance and require double the current. As bill mentioned on top you can get away with using 8ohm speakers, but if you use 4ohm nominal speakers, the amp will effectively see a 2 ohm nominal load. But as others mentioned, comb filtering will be a major concern.
    2Ch Tube Audio Convert
  • aboroth00
    nbrowser wrote: »
    I said it in the other thread, I'll say it here, I see bad things happening...just sayin.
    curiosity killed the cat?
  • snake1
    snake1 Posts: 567
    nbrowser wrote: »
    It may for stereo music but I still like the idea of having wide towers for 7.1 surround. Geoff and I have talked at length about it plus he's had experience with that kind of setup. This was more of a side curiosity for music.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    aboroth00 wrote: »
    So with the 12s everything would work as long as I switch the Amp to 4 ohm mode?
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • Geoff4rfc
    Geoff4rfc Posts: 2,837
    snake1 wrote: »
    On my amps, there is no switch, it just recognizes the impedance.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • snake1
    snake1 Posts: 567
    Geoff4rfc wrote: »
    Mine has a 4-8 ohm switch and a 2-3 side so it could handle it in theory.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • Face
    Face Posts: 14,340
    Just because a speaker is rated at 8ohms, doesn't mean it's impedance curve doesn't dip down to 4 or 3 ohms for a brief period. To run two of these in parallel could be detrimental to your amp, not to mention being a cacophony of sound. On the other hand, to wire them in series, the first speaker's voice coil inductances and crossover parts will effect the second speaker's frequency response, I would pass on that too. If you want a "front wide" setup, pick up a processor with that capability and a second two channel amp.
