PSW505 and Denon AVR-X1000
My sub is really really quiet, the audessy thing tries to give it +25db to even it out, but isn't quite enough. I'm assuming it's a setup issue. I'm using a single RCA from sub out to unfiltered in, I tried both my nice 'sub' cable and a plain red white yellow RCA cable to make this connection, but it doesn't make a difference. I have also tried connecting to the filtered inputs, but can't get it louder than my iphone. I tried both the volume and low pass filter knobs in different positions, and only notice the low pass filter having an effect on the filtered input, which makes sense I suppose, the volume knob works, but doesn't get to a "loud" level. If I play with the auto / standby / on switch the cables I don't hear any volume change, but I can hear loudish ground noises when switching connections on my receiver from the sub. I also have another old amp (Pioneer vsx-d466s mfg in 1997) that has a sub pre out as well as old school RCA outputs (tape2 / tape1), but don't have any luck with it either. I haven't used my sub much until I was upgrading my receiver recently, but then again for all I know it may have always been like this. Currently my monitor 60's provide a majority of my bass notes, which I may have incorrectly thought we're coming from the psw505
Post edited by Headache2012 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited December 2013
    Hello Headache2012,
    Welcome to Polk's forum. Let's see if the sub is working or not. Try this: disconnect all of the cables coming into the sub and turn the sub's volume all the way down. I'm assuming you have a DVD player, if so disconnect it from your system and bring it near the sub and get AC for it. Then take a single RCA cable and run from either the right or left audio output of the DVD player to the LFE input on the sub. Then start playing a CD and turn the volume up a small amount on the sub. You should hear plenty of bass coming from the sub.
    Regards, Ken
    tonyb Posts: 33,069
    Another option is to check in your receivers settings to make sure the subwoofer is set to "on" or "yes". Don't know why the calibration would set the sub level so high, either unless there was a problem with the sub. Do you get the test tone coming out of the sub when the calibration runs ?
  • Snowmanjib
    Snowmanjib Posts: 5
    I have a avr-x1000 receiver, and a polk DSWPro660wi subwoofer. I can't get any sound out of the sub with the direct single RCA cable plugged from receiver to the sub. I do get a little feedback in the sub when adjusting the connections so I know the sub works. When doing the Audessy set up, the test sound was very minimal in the sub, and pre-set the sub to +9db. Any suggestions here? I have the sub set to "yes" on the receiver, the sub set to "on", and the LFE selected. But yet no sound at all when watching movies, listening to music, or DVD!!! Doesn't help either the remote to the sub doesn't work :/ (straight outa the box)
  • recoveryone
    recoveryone Posts: 929
    I very well could be a power plate issue. If the mic setup is setting it at +25 then there is a real problem with the connections/power.
