Common ground question
gmcman
I may pick up a B&K Reference 200.2, I believe this is a dual-mono but not sure. Is the 200.2 a common ground amp? With the Pin/Blade 2B what is the best way to make this amp work if it's not a common ground?
Post edited by gmcman on
NIce amp
I know my B&K ST2140 and ST1400ii are...
You can test between the ground lugs to make sure.
Shouldn't have any load when connecting your meter between the two. -
If it's not common ground you would need an original AI-1 interconnect cable, or even better build yourself a Dreadnaught.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
It's common ground, running the same amp with my 2A's...Remember, when you're running from something, you're running to something...-me
Might want to read the last post before yours...It's common ground, running the same amp with my 2A's...
