psw108
the viny
hello i just bought a pws108, for connection on my amp ....... I have a single coaxial out, while the sub has a L and R are that if I put a Y it will there be a difference
Post edited by the viny on
No Y is needed. Plug into either L or R and you're golden.
Welcome to CP!! -
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
it's not a double voxcoil
tank's
