Something comparable to Monster Z-1 wire?
shepx2
shepx2 Posts: 646
Since I'm going to go with a set of RTi4's, mounted on the wall, I need to find some new speaker cable. I currently have the Monster Z-1 series, in 10 ft lengths. These are too short, and too big in Diameter to easily run up a wall.
Anyone have any recommendations for something that would be under $50, for two 20ft lengths, and maybe a 10ft for my center?
Post edited by shepx2 on
  • Emlyn
    Emlyn Posts: 4,704
    edited July 2004
    With enough left over for some banana plugs:
    Sound King 10 AWG
    Works great.
  • ezc
    ezc Posts: 426
    edited July 2004
    DIY. Monster Z1 uses 6 corse wires & fine strands. Corse for the lows & fine for the mid & highs. 10 guage 14 gauge stranded 6 - 8 strands & 14 guage fine stranded works well, use one corse stranded & one fine stranded to each terminal. Add med stranded wire for even better mids. Been playing with combos for awhile & the right combo sounds outstanding! You may want to find ul rated wire for in wall use.
