Separates for LSI7 PC speakers
Joey_V
Joey_V Posts: 8,520
edited July 2004 in 2 Channel Audio
alright... the LSI7 are officially here and are on their way to staying as the speaker of choice for my computer... a few more days of testing against the Axioms M22s to make sure I am making the right decision.
so, in the process of deciding - i want to maybe entertain the possibility of jumping into the audio world of separates (pre/pro and an amp).... i am more interested in having the front two speakers amped by a separate amp for 2-Channel listening.
i dont really care for the rears being externally amped at the moment - remember, i am a college student and i can easily be broke!! :D
so i was thinking - going with a receiver for pre/pro (preferably with 6ch inputs for analog outputs from the sound blaster audigy2zs soundcard on my computer) maybe by yamaha ... AND a separate amp for the fronts...
I dont want to spend more than i have to... so lets see some affordable tips guys.. nothing overly extravagant now!! as cheap as possible i guess.... :(
HOW does this all work??? I am completely in NEW TERRITORY! help a fellow polkie to be! :)
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Post edited by Joey_V on
  • Sami
    Sami Posts: 4,634
    edited July 2004
    With a computer I'm not sure if you need a preprocessor. Especially since you're going to use analog outputs. If you're going with a prepro, I would use digital output as I'm sure the prepro does a better job than the sound card.
    Get a good 2 channel amp for the LSi7's and cheap 5 channel for the surrounds, connect them to the sound card. Wouldn't that do the job?
  • Joey_V
    Joey_V Posts: 8,520
    edited July 2004
    i can see this can get awfully complicated.... i just want to add a separate amp for the main for 2 channel listening.
    i want to connect all the speakers as well to a receiver so i can do movies as well.
    i was thinking - soundcard (analog and digital) to receiver (used as pre/pro) and then the mains to an external amp.... thats all... is this even feasible??
    i dont even know how the preouts on a receiver work... i mean, is there a preout for ever speaker channel?
    or is it just one preout per receiver?
  • Sami
    Sami Posts: 4,634
    edited July 2004
    I'm just saying that if you're using a computer sound card and its analog outputs, you could just rout it to an amp. No prepro required. I haven't done this myself so it might not work but I don't see why it wouldn't.
    If you're using a prepro or receiver, then use digital output.
  • Joey_V
    Joey_V Posts: 8,520
    edited July 2004
    sami,
    thanks for your quick replies! hmm.. that is interesting.. I will have to check at my local audio store and see what they say about it. As you can see, I know nothing about separates! :D
  • Mazeroth
    Mazeroth Posts: 1,585
    edited July 2004
    HK AVR230 receiver for pre/pro
    Crown XLS-402A for 2-channel amp (400w rms @ 4 ohms)
    Can get both shipped for under $550 combined BRAND NEW. You can't do better than this, trust me.
    EDITED! I meant to type the HK AVR230, not the 225. Sorry!
  • Joey_V
    Joey_V Posts: 8,520
    edited July 2004
    wow... now to find those components... any other suggestions?
  • Joey_V
    Joey_V Posts: 8,520
    edited July 2004
    oops... double post! :D
