Quick question about Fxi's in 7.1 configuration
B Run
B Run Posts: 1,888
edited December 2013 in Speakers
So I just pulled the trigger on a pair of Fxi5's, and am trying to figure out the best way to set my 7.1 up. I'll have the Fxi5's on the walls 90º from my main seat, and move the Fxi3's behind me on the rear wall. Should I set them all to bi-pole or di-pole, or do a combination of the two?
Post edited by B Run on
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    B Run wrote: »
    Polk recommends setting the rears on Di and the sides on Bi. I figure at best, that could be a starting point and that you could experiment with different configurations.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • B Run
    B Run Posts: 1,888
    That's basically what I was getting from everything I was reading, just didn't know if it was better to have them to the same setting or if it was ok to mix an match. I'll try it for myself too but think that's prob going to be my best bet. I'm also thinking 5's on the sides and 3's in the rear unless there is some reason to do otherwise.
  • Geoff4rfc
    Yeah, that's a good call with the arrangement, of course, you could go Godzilla and put another pair of 12's in the rear :mrgreen:
    That's pretty much what I'm doing, I've got two pairs of A9's, which I normally run wide, but due to my smaller room, I'm running them as rears, nothing but clean midrange and plenty of bass, I'm impressed myself!!
  • B Run
    B Run Posts: 1,888
    Haha maybe one day, next step is getting a good 2 channel amp for my 12's.
