Parasound 5250 vs Outlaw 7500
simm
simm Posts: 602
edited November 2013 in Electronics
Anyone have any experience with these two amps? Have not had the opportunity to hear either but looking at adding an amp to the system running through a Yamaha A3000 receiver. 70% music to 30% HT.
Post edited by simm on
    tonyb Posts: 33,070
    If music is your main concern, I would hit the Parasound. What speakers you matching this up with ?
  • simm
    simm Posts: 602
    I primarily run 5 Boston Acoustics VR-M60 bookshelf speakers but sometimes swap out for SDA-1C in front and monitor 10's for rear channels.
  • codyc1ark
    codyc1ark Posts: 2,535
    simm wrote: »
    Hate to derail, but can you comment on using a 60 for your center, I've been hunting a vr12 for a bit now and haven't had much luck. I've never had my ears on an outlaw amp, but I would think you can't go wrong with the Parasound...
    tonyb Posts: 33,070
    Those speakers are pretty easy to drive and your receiver is definitely powerful enough. What are you hoping to gain by adding an amp ? Or is there something else that doesn't sound right in your system your hoping to correct ?
  • simm
    simm Posts: 602
    codyc1ark wrote: »
    I've been using 5 VR-M60's for several years. I think using all 5 of the same speakers really gives a better sense of cohesion to the sound. I have a pair of VR-MX surrounds that I haven't used in several years that I keep meaning to pull out and run a 7.1 system but don't feel like running the wiring through the walls to do it right.
  • simm
    simm Posts: 602
    tonyb wrote: »
    Primarily considering an amp for when I want to run the SDA's with sufficient power and also to slowly start the upgrade to separates.
  • michael1947
    michael1947 Posts: 775
    I have used the 5250 in my HT for about a year but just downsized to a receiver only and some bookshelves, RTI A3, CSI4 and a couple of Klipsch KG 1.5's in the rear. The Parasound replaced an Emotiva XPA-5 which worked just fine but maybe a little sterile. While in service the 5250 worked magic for my RTI-A9-s and my modded SDA-SRS's. It produced a powerful, clean, warm sound and was bi-amped for both of the big towers. I have no experience with the outlaw.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
